Symptoms: After engine warms up, there's a knock coming from the top center of the intake manifold. Can only hear it when engine is at idle. It can be felt most noticable through the upper heater hose.
The rotating assembly on my 5.0/302 was recently disassembled and balanced. Before the engine was disassembled, there was no knock. Two engine builders advise there is nothing mechanically wrong and it's probably an air pocket in the cooling system. However, I've followed the standard protocol for bleeding the cooling system. Fill radiator to about 2-3 inches from top. Start engine and when T stat opens, the system burps. When burping stops, it appears all air is now purged from cooling system. I turn off the engine. Top off radiator. However, the engine still knocks. I've changed the T stat (180) to make sure that was not the problem. I've lifted the front end when filling the system to help get any air out of system. I've checked the highest point (upper heater hose) and it appeared to be full, with no air pockets.
1968 mustang, 5.0/302 (90's block), edelbrock performer intake manifold, griffin 3 row aluminum radiator, cool flex (ribbed) hoses, roller cam, roller rockers (hydraulic), ford racing valve covers (tall style)
Any ideas?
Any ideas?
