302 swap?
ahhjaws
55
Fort Collins, CO
Hey, just wondering what might be involved, how easy it would be to swap in a 5.0L HO? Would I need to swap trannies? Wiring harness? It should fit into the existing motor mounts right?
This will be a project motor. I will probably rebore it out to a 347 while I'm at it. Supercharger, turbo?
This is just in the planning stage, so any thoughts would be appreciated.
If you are talking about your 97 GT, it will be a PITA. Almost all body wiring will need to be swapped, need a different tranny (T45 doesn't match 5.0 bolt pattern), it will fit the mounts, but a lot of other things would have to change. The better way would be to buy a 94-95 5.0 stang and use that for your build up. Good luck!
