306ci single turbo setup **cheap**
Knarias
Ok so I'm going to change quite a few things on the notch so I'm looking to sell my whole setup (is still in the car so u can see it run) list of mods:
306ci (all work done @ LPM in Cocoa FL)
Probe Dish pistons/pins
Plasma Moly rings
Std. Clev. Rod bearings
Std. King Main bearings
Eagle h-bean rods
Main Gridle
Polsish crank
Moroso oil pan
Cometic head gaskets
Melling select oil pump/hard oil pump drive
Double roller timing chain/gear
Gt40 head
Ported/Polished
E-303 camshaft
Ford motorsports lifters
Viton valves seals
5 angle valve job
Ford racing valve covers
Cartech intake (I'm keeping the lower and upper intake)
T5 tranny
New clutch cable
Pro5.0 shifter
King cobra clutch/new 3 pc clutch quad kit
Custom Single Turbo kit
Holset HX40G turbo
Custom 4" downpipe
Tial old school wastegate
Turbo blanket
Evrything is powder coated
Running 10psi at the moment
42lb injectors
Accufab regulator (I'm keeping the regulator)
I'm looking to sell everything as a package , I will not sell the lower/upper intakes, any of the ignition, but I'll let it go w a terex pusher pump and an intank walbro 255... A few people have seen the car run, is a solid setup... I'm looking to get $4800 for everything (again, everything is still in the car so u can see it run) no lowballs pls.
I do not want to part out since I'm going a different route and don't have a need for this setup, I'm located in north Fl text me if interested 904 402 0four33. Motor and turbo still in the car, so u can see it run, no issues I'm going a different route w the car so I need this gone.
