30lb injectors
Daniel50
716
Discovery Bay, CA
i am getting a custom chip burned when i get my car tuned. i will be running a 125 shot of nitrous with my current mods in my signature. now my future goals are heads and cam and a small amount of boost. now since im getting my car tuned i can go ahead and run 30lb injectors cuz my tune will compensate for it correct?
You using a wet or dry kit? If its a wet kit, you don't need injectors. The tune will make the 30's work fine if the shop knows what they're doing. My 30's work fine and I tune it myself with a PMS. The 30's will be WAY too small for a blown h/c/i car so you'll be selling them when the time comes.
Don't forget if its a dry kit, your n2o jetting will need to be changed too.
the way my kit is designed is the nitrous line sprays the air filter, the mass air makes up for fuel increase and has a inline jet at the solenoid. it comes with 20-125 shot jets. i going to put the 125 jet in. this would not be a 125 shot?
