Almost finished with the build of my 331 going into my 95 gt vert- so far we pulled the motor and tranny and repainted the engine bay the future color of my car (House of Kolor Shimmering basecoat Cobalt Blue) and installed a UPR K-member kit with coilovers.
The specs on the motor are:
302 block machined and notched for an Eagle 331 stroker kit w/probe pistons with 9.5 compression, Probe Pistons cut for TW heads
Comp Cams Extreme Energy XE274HR-12 cam (valve lift .555/.565 duration 224/232, lobe lift .348/.354, lobe separation 112)
Twisted Wedge Track Heat heads (ported and gasket matched)
TW Street Heat Intake
75 mm TB
75 mm Mass Air Calibrated to 30lb injectors and CAI
BBK CAI
30 lb injectors
BBK shorty headers
1.6 RR
other things going in as well are:
255 LPH intank fuel pump
Trunk Battery Relocation kit
Spec stage 2 clutch
Tremec T-56
Steeda Triax Shifter
aluminum DS
Wazee pulleys (idler, tensioner, and PS pulley)
Currently I have installed:
3.73 gear, Lakewood Traction Action LCAs, bilstein shocks, MM 4bolt CC plates, H-pipe, Flowmaster exhaust, Tweecer R/T, PLX M-300 WB O2, Fluidyne Radiator, Cobra brake upgrade kit
Spent most of the day putting all the wiring harnesses back in place and removing the accessory brackets and accessories (PS, A/C compressor and alternator), and cleaning them up for repaint (we have painted the motor the same cobalt blue and used silver as well)
Hopefully tomorrow we will be able to drop the motor and tranny in and see how everything mates up (still have to get miscellaneous parts like new sensors, plugs, etc.) It's been a scary but exciting experience (just hate seeing my car in a million pieces
) but it's been progressing well. I'll see if I can post some pics soon, but wanted to hear some comments.
Thanks!
75 mm TB
BBK CAI
30 lb injectors
BBK shorty headers
1.6 RR
Spec stage 2 clutch
Tremec T-56
aluminum DS
) but it's been progressing well. I'll see if I can post some pics soon, but wanted to hear some comments.Thanks!
