Engine 331 Cam Choice.
  • Thread starter Thread starter 2011rustang5o
  • Start date Start date Sep 30, 2016
2011rustang5o
113
Sep 30, 2016
  • Sep 30, 2016
Bought a 93 lx coupe with a DSS 331 stroker kit, track heat heads and upper/lower intake, 70mm throttle body and maf. I believe 24lb injectors.
The cam I think is too aggressive (unknown specs except "custom blower cam" on the build sheet). It's pretty damn choppy and surges/bucks between 1600-1900 rpm cold or warm.
What's a decent off the shelf cam? Not going for power numbers but just a street friendly cam with lope.
Sent from my iPhone using Tapatalk
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Sep 30, 2016
  • Sep 30, 2016
Have you ran any codes to make sure it's not something else? Or a vacuum leak? There are a lot of cam choices but would need more info from you for a recommendation. My advise is to check out comp cams,Lunati,Bullet cams and fill out their forms for a recommendation.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 30, 2016
  • Sep 30, 2016
Surging and bucking at that RPM is common with most aftermarket choices if all you're doing is a bolt in and go. Spend the money you were going to drop on a cam, on custom tune, from a reputable tuner. You've gout enough done to the car that it's running out of the stock ECU parameters.
Swapping out to a different cam isn't going to dramatically improve drivability...or power for that matter, but having your ECU reprogrammed to maximize your current set up will.
2011rustang5o
113
Sep 30, 2016
  • Sep 30, 2016
Well it had a egr code, evap canister code and speed sensor no continuity. I think those were old codes. Since I got the car iv replaced the o2 sensors, iac, speedo gears, speedo cable and cleaned the maf as well as properly set idle and tps. I flushed out the codes and earlier there were no more codes. Only issue is it might not have enough drive time to reset the codes yet.
Base timing is at 10 and it has a flip chip with the paperwork showing a dyno tune back in 06.. tried 14 degrees of timing and it didn't like that at all.
2011rustang5o
113
Sep 30, 2016
  • Sep 30, 2016
No real shops up here that do tuning so I'm gonna have to wait until next summer when I go back to Texas. Thought about a mail order tune but I doubt that will be worth a damn.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 30, 2016
  • Sep 30, 2016
24's are too small for any decent built 331. For the cam, spend the extra $75 and email Ed Curtis at Flow Tech and have him grind you a custom cam.
2011rustang5o
113
Sep 30, 2016
  • Sep 30, 2016
Maybe they are 42lb injectors. Il check tomorrow.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 30, 2016
  • Sep 30, 2016
If the VSS issue hasn't been sorted out, get that fixed before you look into swapping cams. A bad VSS signal will add to the jerky drivability that you described.
A functioning VSS is a must on a MAF car.
2011rustang5o
113
Oct 1, 2016
  • Oct 1, 2016
Will do. Kinda pissed off that I put new speedo gears in and a new cable and the still has a slight bounce to it.
So if there is no continuity in assuming it's either VSS or VSS wire harness.
2011rustang5o
113
Oct 1, 2016
#10
  • Oct 1, 2016
  • #10
Only code I have now is 87. Fuel pump circuit d2. Gonna change the fuel filter today and see what's up.
2011rustang5o
113
Oct 1, 2016
#11
  • Oct 1, 2016
  • #11
Update: pulled the plugs (new autolites) and regapped to 50 and threw in a new fuel filter. Barely any bucking now. Will need to do a complete drive cycle to see if any codes come back.
Coming from the land of obd2 cars (2014 gt) these dinosaur obd1 cars with zillions of adjustable parts is a learning curve. Actually loving it so far.
Progress Thread Dirty Water Racing 89 Notch Project
  • ShedBuiltMS
  • Sep 29, 2020
  • 2 3 4
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2021
Flyboy60
F
Engine Bucking While In Gear.
  • 2011rustang5o
  • Oct 4, 2016
  • 2 3
5K
Fox 5.0 Mustang Tech Oct 23, 2016
General karthief
Exhaust 2.5 Vs 3" Tail Pipes
  • 2011rustang5o
  • Oct 28, 2016
9K
Fox 5.0 Mustang Tech Oct 30, 2016
General karthief
Cam Advice For A Supercharged 331 Stroker
  • blotte1
  • Sep 30, 2016
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2016
blotte1
  • Locked
For Sale [for Sale] 1990 Mustang Lx / 331 Stroker / 67k / Lots Of Upgrades
  • Denethor
  • Mar 6, 2017
7K
Fox Body Mustangs For Sale (1979-93) May 6, 2017
Chris powers
C
