Thinkin about having a stroker motor built, Going to be running a vortech s trim supercharger on this, what is the better performing stroker motor 331 or 347, i was told to go with the 331 but do not know why! any help would be appreciated thanks
yes you can, the DSS blocks are also stock blocks, that will still split at the main webbing at the usual hp levelstkolstad said:can i use my existing 90 302 block to make a 347! Or should i get a dss block or something similar.
bynummustang said:Depending on how much boost you want to run, I'd go with the 331. The shorter stroke and shorter rods will work better with high boost.
5spd GT said:In your case, I would pick one or the other. Stroker will give you less power for more money, or you can go blower for more power and less money.
88Stang331 said:How do you figure more displacement would net you less power?
blkcobra50 said:Stock block, notch the skirts, 347 rotating assembly w/blower pistons, s trim sound great but at block splitting power.
331 and 347 have same length rods at 5.4'' with their own respective pistons. CHP has a shorter rod at 5.315" with 331 piston for their 347.
