  • 1994 - 1995 Specific Tech
331 Stroker Plugs & Timing?
  • Thread starter Thread starter FeTTstang
  • Start date Start date Dec 1, 2006
F
FeTTstang
61
  • Dec 1, 2006
Hey everyone. I have a 95 5-speed with a 331 stroker with 10-1 compression with GT40P heads and TFS intake and cam. I have NGK TR4 plugs and I cant get it timed right. They are the coldest plugs that NGK has for the 302. I have tried every timing setting from 8-14 and it pings at no matter what I have it set at. I have also tried one step hotter plugs earlier and it still pinged. What plugs should I use for this motor? I dont care what brand and I don't want fancy platinum ones either. Any help would be great.
ProKiller
3,064
15
78
PA
Dec 1, 2006
  • Dec 1, 2006
autolite 3924s
F
FeTTstang
61
  • Dec 1, 2006
Are they gonna be colder than the NGK TR4's?
95cobraguy
637
11
Concord, NC by way of LI, NY
Dec 1, 2006
  • Dec 1, 2006
ProKiller said:
autolite 3924s
i agree. get rid of those ngk's (which belong in nissans) and put the autolites in (which belong in fords with aluminum heads). if u want a colder plug than the autolite 3924 than u can go with an autolite 3923, 3922, etc.
ProKiller
3,064
15
78
PA
Dec 1, 2006
  • Dec 1, 2006
no clue, but that's the plug that pretty much everybody runs.
F
FeTTstang
61
  • Dec 1, 2006
I have iron P heads tho. Should I still run the autolite 3924's still?
OrangeMustangGt
1,976
Cape Cod, MA
Dec 1, 2006
  • Dec 1, 2006
If you have gt40 p heads, then you need autolight 104's or 103's for a colder plug.
i run 103's with 10lbs of boost ob my gt-40p heads and they are cold enough, but you might still be able to use a 104 n/a
the plugs people are talking about above are not for gt-40p heads, which take a special plug due to sparkplug placement for "fast Burn" combustion chambers.
WhiteDevil
2,717
San Diego
Dec 1, 2006
  • Dec 1, 2006
WHy would you need super cold plugs for your stroker? I run Autolite 3924s(stock heat range) on my 347 and they work great.
F
FeTTstang
61
  • Dec 1, 2006
It does not work with the stock plugs it pings, my tuner told me to try colder plugs.
legalize420
1,541
South Florida
Dec 1, 2006
#10
  • Dec 1, 2006
  • #10
i think the 3924's are for aluminum heads. i read that iron gt40 heads use autolite 764's. i know thats what i had in mne. i went to the 103's for nitrous
F
FeTTstang
61
#11
  • Dec 1, 2006
  • #11
I think I will get some autolite 103's and see how they work.
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
