331 stroker question
  • Thread starter Thread starter fv0stang90
  • Start date Start date Apr 27, 2008
F
fv0stang90
10
  • Apr 27, 2008
Hey guys.
I have a 331 in my 90 LX. twisted wedge head. trick flow upper and lower intake. 30LB injectors matching MAF. Car was just not running right after installation. Seemed as if it was getting too much fuel. People have told me its because i need to have a chip burnt for the car. Is this what i need to do or is there something else wrong?? Any help is appreciated. Thanks
ATISTANG
104
  • Apr 27, 2008
i would double check all the grounds, there is an orange one on a harness that runs along the passenger side of the engine, if you leave that off the tps voltage will be way out
have you tried to pull any codes out of the computer?
F
fv0stang90
10
  • Apr 27, 2008
I will check for that ground. No i have not tried to pull any codes. Just kind of figured it needed to be tuned for the setup i had.
F
fv0stang90
10
  • Apr 28, 2008
Any other suggestions???
Flavadave4
1,044
21
49
Utica, NY
Apr 28, 2008
  • Apr 28, 2008
Hey Dan, good to see you on here!
I still think you are fine without a chip burnt, Gotta start with the codes, although it may or maynot have a check engine light on there still may be codes present.
This thread covers about everything needed to make the car run and function properly...might give you some ideas.
http://forums.stangnet.com/showthread.php?t=698148
Alot of good reading here as well
http://fordfuelinjection.com/?p=1
See ya later...
9
90bluecoupe
76
Abingdon md
Apr 28, 2008
  • Apr 28, 2008
If you think its your fuel turn it back some. What do you have it set at?
Flavadave4
1,044
21
49
Utica, NY
Apr 28, 2008
  • Apr 28, 2008
39 psi with the vac line off, Engine warm and idling...I helped him put it together.
ls1beater4eva
334
mooresville
Apr 28, 2008
  • Apr 28, 2008
whats the timing at ? what cam is in it?
Flavadave4
1,044
21
49
Utica, NY
Apr 28, 2008
  • Apr 28, 2008
He is running a X303 cam, I believe we ended up with around 14* of base timing.
mustangfan1990
505
Lenoir, North Carolina
Apr 28, 2008
#10
  • Apr 28, 2008
  • #10
Could be a MAF sensor fault but that would show up in the codes. Ummmm a chip would def help in performance but a 331 is still sucking in the air on its own and not being forced which I would say the computer witha stock tune could handle the job.
Flavadave4
1,044
21
49
Utica, NY
Apr 28, 2008
#11
  • Apr 28, 2008
  • #11
That was our deductive reasoning. The MAF is brand new, clean and matched for the injectors so I cannot see that being the problem, unless there is a voltage issue.
Other thoughts have been an injector sticking open, we are going to pull the plugs this weekend and see if there are any things that stick out.
F
fv0stang90
10
#12
  • Apr 28, 2008
  • #12
Yea, gonna try to see if its throwing any codes at all and go from there. Im hoping its something simple. Dont wanna have to spend more money on tuning it if i can fix it myself. Yea im running an x 303 cam in it with 14 degrees base timing. Turning my fuel pressure down as low as it could go but still seemed way to much. When i would put vaccuum line back on it didnt seem to change it much though so i was also thinking of a possible vaccuum leak somewhere too???
H
haoleboy72
60
Hillsboro, OR
Apr 29, 2008
#13
  • Apr 29, 2008
  • #13
i agree with everyone else that you should check codes and the other basics first, but I disagree that you don't need a chip. With a dyno tune your able to see your power curve and more easily see where your issues are and best adjust the timing and A/F mixture to maximize your output throughout the whole curve. My car ran like a champ but we were able to squeeze out another 26hp and 19tq just by adjusting A/F and timing, and you can feel the difference in every gear thru the entire power curve. I am very glad I got my car tuned...just my $.02.
Flavadave4
1,044
21
49
Utica, NY
Apr 29, 2008
#14
  • Apr 29, 2008
  • #14
I forgot about that, I know whenever I check my FP as soon as you put the vaccume line back on the pressure changes...we should replace the line between the intake and FP regulator.
F
fv0stang90
10
#15
  • Apr 29, 2008
  • #15
yea. we could do that. i need to get car to the garage one day this week...
Flavadave4
1,044
21
49
Utica, NY
Apr 29, 2008
#16
  • Apr 29, 2008
  • #16
You mean you need me to come over and steer while you push it from the house to the shop?
F
fv0stang90
10
#17
  • Apr 29, 2008
  • #17
hahaha yea, gonna have to get a running start to get up that hill.
Any other input is appreciated. As of now, once i get it to garage im gonna check for computer codes and couple other simple things and go from there. Thanks for everyones input.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
