331 Stroker with DSS Main Support System???
  • Thread starter Thread starter fivebugles306
  • Start date Start date Jan 12, 2008
F
fivebugles306
North Middletown, Kentucky
Jan 12, 2008
  • Jan 12, 2008
I'm building a 331 Stroker for my 93 LX. The shortblock came with a DSS Main Support System and Windage Tray. When I tried to install the Oil pump pickup tube - it hit the side of the support. (1) Has any body had experience in building using this unit? (2) Will it hurt my oil pressure or volume to dent the side of the tube to make it work?
My aftermarket oil pan seems to clear the support - unlike some of the post I found. Also, I found the dipstick hit the support, but I was able to "tweek" the dipstick tube (BEND IT) to allow the stick to slide past the support.
Any experience should make my install easier!!!!!!!!!!!!!!!!!
Thanks - - - -
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 12, 2008
  • Jan 12, 2008
A couple things to keep in mind...
1. You need to make sure that you keep a proper clearance between the pick-up tube and the bottom of the oil pan. The goal is to make sure it is not to far from the oil (if it gets low) or to close to the bottom (creates a blocking/starvation problem. I have read 1/2" is a pretty standard setting, but I would check that.
2. Denting the pick-up tube is something I would be vary wary of duting. The last thing you want to do is restrict the oil flow to the pump.
Hopefully someone can help you much better than I so you can get that thing on the road
F
fivebugles306
Jan 15, 2008
  • Jan 15, 2008
Any suggestions on the oil pickup tube before I mess up and smack it with a hammer??????
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 15, 2008
  • Jan 15, 2008
got a pic?
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Clearance Issues Between Main Cap and Oil Pump in 347 Stroker Engine, Previous Pump Damage
  • Swhitney
  • Feb 28, 2024
2K
Fox 5.0 Mustang Tech Feb 29, 2024
Bullitt347
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
