347 injetcor??
ls1beater4eva
334
mooresville
ok well i have my nice new 347 in and it runs pretty good , but i have 30 # injectors and everybody is saying that they are to smal for the set up it has a 588/605 lift cam 226intake dura tion@50 and 236 @50 on the exhaust with afr 205 heads 11.1 comp and a holleysystemax inatake 70mm tobod and lts and a 150 shot of nos and i am going to a 175 shot and wanted some opinions on if i really do need larger injectors or not and it has a 255 fp and adj fpr.
i am allso considering going to the spider intake is it worth the swap?
Yeah I would say those injectors are a bit small, even with a wet kit. If you were N/A the 30's would be just fine.
Grn92lx - Bump up your fuel pressure.
5spdGT, no thanks. I'd rather not do it incorrectly and make a global change to fix a WOT higher rpm issue. Thanks though :) Not looking to re-tune the combo again.
ok well i was just curios b.c i have some 36#injectors and was wondering if it would be worth the swap btw its a wet kit 150shot ,allso what would cause a pcv valve to keep pulling oil through a seperator it keeps filling it up and its a brand new motor the baffel that the little filter sits on is staying full of oil would a vac leak at the lower or somthing like that cause it? i dont know im just getting frustrated with it now and allso i have the baffel in the valve covers removed for rocker clearence would that cause this issue?
36's are the ticket.
Do you have the oil baffle on your lower intake installed? I have also read the stock pcv system isn't always enough for strokers so who knows.
