I am normally a part of the classic forum but need some help from you 5.0 guys on my cam's lift. I have a 347 with GT 40 Irons and am trying to run an Anderson cam with .544 lift with my 1.7 rockers. The car ran for 2 hours and then at idle it hit an intake valve and locked down. I disassembled it and talked to ford's tech line and they stated these heads are off of a 93 cobra and it should be fine for that lift. I stated that the heads had 2 springs and they said that I needed new springs, ret, & keepers. which I have just changed. Am I missing something? Valve spring bind? I dont want to hurt the lower end if this happens again.
if that head has a stock spring hes got issues at near 580 thou. Thats where I was going. Who knows the deck height of the block, what head gasket, heads been cleaned up?
