347 Stroker Parts List?
  • Thread starter Thread starter stangsta89
  • Start date Start date Aug 8, 2011
stangsta89
26
Mesa, Arizona
Aug 8, 2011
  • Aug 8, 2011
i am wanting to put a 347 Stroker kit in my '89 5.0 GT but i need help in gathering the list of parts. i know i need the kit, 28 oz harmonic balancer and flywheel, but that's about all i know that i need to do this build. any suggestions?
Thanks
PUNISHER RACING
1,124
FORD CITY, PA.
Aug 8, 2011
  • Aug 8, 2011
not all kits are 28 oz. u can get it balanced to 50 if u wish. the 0 and 28 are far more popular tho
R
reldla1996
356
22
Dayton, Ohio
Aug 8, 2011
  • Aug 8, 2011
The sky is the limit; what are your goals and desired Hp levels? Heads, cam, intake, throttle body, mass air flow sensor, injectors, fuel pump, headers, and exhaust system all come to mind, depending on the goal. Maybe a windage tray?
stangsta89
26
Mesa, Arizona
Aug 8, 2011
  • Aug 8, 2011
i have no desired final HP really, but i plan on putting GT 40 heads and intake on it, plus a cam but i'm not very educated on cams yet. i have a 70mm throttle body installed, and have a larger MAF ready for install. have full flowaster with equal-length shorty headers. don't have plans for fuel system yet. how much HP could i get out of all this (approximate)?
R
reldla1996
356
22
Dayton, Ohio
Aug 9, 2011
  • Aug 9, 2011
Hp can vary from 300 to 450, roughly, depending on the exact combination of parts. Ideally, all the parts from mass air flow sensor through the exhaust pipes should be sized to work together, and the fuel system will need to be upgraded unless you are at the very bottom of that scale. The GT 40X heads are decent heads, but the older GT 40 heads are on the smaller side for a 347. No matter what, the torque from a 347 will be fun on the street.
D
DonMaximo
217
Lewisville, Texas
Aug 9, 2011
  • Aug 9, 2011
This question is vague....
You can spend big coin on the reciprocating assembly -OR- reuse some part and cut costs...This area is where the most money will be spent.
Will it be street only ?
Do you want to build a simple 347 and just stop there... or will you continue to add products to the engine...and do you plan to have the EEC tuned -OR- cut costs and drive it AS IS...
This information will help you obtain specifics... and possibly links to good sources for what you're looking for.
In the least, for a 347
#1 - Upgrade fuel pump (while you're in here, I would go with a 255GPH)
#2 - 30# fuel injectors
#3 - A new/used MAF which is calibrated for 30# injectors.
#4 - On most 347 combos, the engine block will require clearancing for the new crank stroker.
On a rebuild like this, there will be machining costs if you want the engine to last a reasonable
period of time. A few hundred bucks need to be accounted for in your budget
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
