351 CLEVELAND ENGINE WITH 4Brl HEADS FOR SALE
KrisD
Nebo, NC
Ford 351 Cleveland 4 Brl Engine
Check it out on eBay: 351 CLEVELAND 4 BRL ENGINE WITH HEADS - 351C - eBay (item 190556453880 end time Jul-27-11 20:25:56 PDT)
This engine appears to have been rebuilt and never fired. It has no carbon build anywhere. It has many new parts - pistons, cam, bearings, intake, etc. It will need to be completely torn down, rehoned and cleaned, as it now has small rust pits on the cylinder walls after sitting for decades.The crankshaft has an engraving of R. .030 M. .030
Double roller timing chain
Camshaft appears to be a new - still covered with grease
.275 lift on the intake lifter
Block #s: DOAE-J / 9K23
3.500 stroke
.040 over bore
Offenhauser 4brl split port aluminum intake
Heads appear to have a mild port polish
Small combustion chamber (closed chamber)
2.190 Intake
1.700 Exhaust valves
Head #s: DOAE-N / 9H26 / 9K23
The engine has a balancer, water pump, fuel pump, exhaust manifolds, valve covers, oil pan, intake, rotating assembly.
The heads and oil pan have been removed so it can be inspected. All parts are present.
