Light truck 351's from maybe mid-94 & up have roller compatible blocks,
although they're not quite as strong as earlier blocks, but still considerably stronger than a standard 302 block. But with one of those you can use stock 302 roller cam hardware and lifters which is lots cheaper than retrofit hydr roller lifters.
If you don't get one that originally had a serpentine belt setup, then
you'd also need to get the serpentine crank pulley and spacer. Look
in
www.alternativeauto.com their water box archives for a complete
Ford part # list for that and other stuff. (That and other links are in
the article I linked, below)
Your efi system will plug right in if you use an injection setup on the 351.
If you use a stock 351 or one with just a mild cam, you're probly OK with the 19 lb injectors. But the stock throttle body etc will really choke a 351, even a real mild one.
Awhile ago, I did a search and a Wanted Ad on Corral.net and found 24 lb injectors and a Pro-M larger meter calibrated for 24's used, or the new Pro-M outfit now sells them, too. If you're going mild, you can adapt a GT-40 or Cobra (need one with the interior EGR port) or early Explorer (much like a Cobra & the early ones have the interior EGR port so your system will fit right up & can be had quite reasonable at junkyards & by shopping around the internet) using Weiand/Holley or
www.pricemotorsport.com spacer adapter plates. I wouldn't bother adapting a stock 302 intake unless you want the engine to sign off in mid range. If you're going much over 380 horse or so you'd need 30's and at least a 75+ meter and throttle body. Also either the Trick Flow intake or the Edelbrock 351 lower with like a 302 Performer RPM or bigger upper. The TF is a great efi 351 intake.
For a budget mild build, iron GT40's would be good up to maybe 350hp and reasonably priced. If you're going much stouter, then you'd need more. AFR 185's are great for stout 351's. I happened to find a used set of Ebrock 1.9 intakes alum heads for $600, and they're not a WHOLE lot behind the newer "latest greatest tech" heads like AFRs, and my motor is fairly mild so I got what I needed pretty reasonable. Pays to shop around.
If you go an earlier block , you'd need to make sure to get a 351 or 302/5.0 HO flat tappet cam so it has the right firing order - a non-HO cam has a diff order. That's if you don't want to spend the about $400 for retrofit hydr
roller lifters so you can use a roller cam.
Even on a mild engine, you'd need to get the computer dyno tuned to reset some things like the timing curve (reset the parameters to 351 cu in instead of 302, etc which affects the load table in the computer) so you can get it to run right and don't burn it down from too much timing advance etc. - & there's other things but I'm no computer expert. I happened to find a relatively rare 70mm Ford meter made for use with 30's, but I'm still going
to get it dyno tuned to get the cu inches & other things reset inside the computer.
For the rest of it here's how I did mine in an 89 Linc Mk7 which is just a longer Fox chassis.
Any questions, feel free
[email protected]
www.lincolnsonline.com/article144.html
It's more work and expense than going to a bigger smallblock with
Chev & Mopar, but it can be done. Nothing overly difficult.
Everything considered, you could rebuild your 302 with a 331 or 347 stroker
kit for maybe about the same overall cost, and actually have at least as much power cuz the lighter crank/rods/pistons rev quicker than with a 351. (I prefer 331's cuz some - not all - 347's have oil use problems cuz the
piston pin is up in the oil ring groove - if you go 347, get one like Coast I think with the shorter rod but offset pin so you don't have such a bad rod angle which accelerates bore and piston wear on the thrust side cuz the rod is so short) One advantage, however, with a 351 is that you can do a cheap 393
using a ~$250 cast crank, stock 351 rods, and stock 302 pistons. (Just to plant a little evil seed ;-))
