351 Swap Info
SVT-Sinister
39
PSL, Florida
Hi, I'm gonna be swapping in a 351/408 into my 95 GTS. Aside from the distributor, oil pan, intake, exhaust and hood, is this an easy task??? I know I'm gonna have to find a way to deal with the front accessory drive setup but any info on this swap would be greatly appreciated. Thank You.
On a more positive note, it is very possible and simple when patience is around you. I swapped a 351w into a v6 and it was fairly simple. I don't have stock accessory brackets, however I did read before that the brackets from 302 fit a 351w. As far as timing cover, you can use a 302 also.
