351w block
  • Thread starter Thread starter twindragons187
  • Start date Start date Dec 8, 2005
T
twindragons187
39
pa, ny
Dec 8, 2005
  • Dec 8, 2005
ok, please don't shoot me for asking this, i've done a search and found nothing i'm looking for. i'm curious on what year 351w block or complete motor i can use for my fox? and what price's i'm looking to see when i go looking? i'm right on the border of pa and ny, middle of the state. any info would b grateful, thanx.
duston
M
MatthewP
355
Calgary, Alberta
Dec 8, 2005
  • Dec 8, 2005
Any year 351W will work. '83 and up use a one piece rear main seal, which leaks a little less than the older two piece style and can be replaced without pulling the rear cap. The earliest blocks have a slightly shorter deck height, but that's only the first 2? years or so of production.
Price for a rebuildable core could be anywhere from free to maybe $300.
-Matthew
soontobefastfox
275
Troy, Michigan
Dec 9, 2005
  • Dec 9, 2005
if you want the strongest blocks look for a 69-73 351w because they are the strongest. But any 351w will fit into your fox with modifications. Whats your plan?
blackcloud50
388
  • Dec 9, 2005
I think if you want the block already set up for hydraulic roller you would need one from early '90s I believe. Someone please correct me if I am wrong.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Dec 9, 2005
  • Dec 9, 2005
69-74 were the best blocks,69-70 had a just shorted deck hieght (I forgot the exact munber).
Like said,90's 351W are set up for a roller cam.
The mounts are the same as your 302....
Did you want a specific answer about something?
T
tjm73
2,418
Rush, NY
Dec 9, 2005
  • Dec 9, 2005
I think all roller cam 351W's are F4TE blocks That's a '94 truck engineering number.
Any 351 block will work. Pre-70 deck height is 9.480". Post-70 deck height is 9.502". Both per FRPP catalog.
I have read in more than one publication that all 351W blocks are the same structurally as far as strength is concerned.
The only significant differences are.....
rear main seal type
deck height
roller vs. flat tappet cam support
All were 2 bolt main.
soontobefastfox
275
Troy, Michigan
Dec 9, 2005
  • Dec 9, 2005
thats correct but 69-74 they had a higher nickel content making them stronger.
and I believe 69-70 (please correct me if I'm wrong) they had closed chamber heads.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Dec 9, 2005
  • Dec 9, 2005
Yea,they do have a higher nickel content but also are said (and I think its true,I got a 74' 351W block in my shop and there is a differance) they have thicker main webbing,and also the 69 block have a thicker/flatter main bulkhead,so you can effectivly use a 4 bolt main cap.And last,I think that the pan rails are probably better on the older blocks.
And I have a set of D0OE head sitting in my shop (which I was pratcing porting...think I messed up one,heheh) and I got them with the 74' block,so I dont know
T
twindragons187
39
pa, ny
Dec 9, 2005
  • Dec 9, 2005
ok thanx. i was just wondering. i have a blue printed 5L i'm swapping in my 92 lx. now, they say that u need to buy an aftermarket hood too?? now i have a 3 1/2 or 4 inch ram air hood.(was freeeee!!!!) that should clear the intake correct? thanx again for all the help.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Dec 9, 2005
#10
  • Dec 9, 2005
  • #10
Yea,that should clear no poblems.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
