351W question for my '68
  • Thread starter Thread starter stang1986GT
  • Start date Start date Sep 13, 2007
stang1986GT
143
Charleston, WV area
Sep 13, 2007
  • Sep 13, 2007
I just purchased a 351W from a buddy. Got the engine, C6 transmission and transfer case for $300. All of this is out of a 97 or so Bronco. I bought the engine to put in to my '68 coupe. I don't want to leave it fuel injected or anything like that...I want it streetable as I want to drive it a lot, but I want a cam that will give it some "lope" and good power from 3-5000 rpm.
What do I need to change on the engine to convert it to a carbed engine? Just the intake and cam? I assume I can use the same heads. Isn't that a roller motor...can I just find a cam that will work with that? What would you suggest? Any other suggestions on what you would put this engine together with?
5.0ina66
664
Ohio
Sep 13, 2007
  • Sep 13, 2007
All you have to do to carb it is to swap the intake, add a carb, and plug the smog holes in the heads. You'll also need a correct oil pan, pickup tube, dipstick, and exhaust manifolds/headers. I don't know an awful lot about 351W swaps so I hesitate to say more.
I'd put on an Edelbrock carb and a PerformerRPM intake (and I happen to have one for sale over in the classifieds )
As for hopping it up, how far do you want to go? Off the top of my head, I'd use a Trickflow #2 5.0 roller cam, but there are better ones out there for a lot of builds, it just depends on how you want to build it.
EDIT: That ain't no C6, its an E4OD, which is way too damn big to fit in a mustang.
stang1986GT
143
Charleston, WV area
Sep 13, 2007
  • Sep 13, 2007
Don't I have to swap out the cam too? Aren't they ground differently or something?
The tranny isn't going in the Mustang...I'm going to put a 5 speed in it. It's a 6 cylinder 3 speed now.
5.0ina66
664
Ohio
Sep 13, 2007
  • Sep 13, 2007
Huh? You don't *have* to swap out the cam unless you want to. You'll need a distributor with a steel gear to carb it too BTW.
stang1986GT
143
Charleston, WV area
Sep 13, 2007
  • Sep 13, 2007
What about the fuel pump? If I run a mechanical pump, what about the pump eccentric? Will I have to run an electric pump?
5.0ina66
664
Ohio
Sep 13, 2007
  • Sep 13, 2007
It ought to be like a 5.0 and if it is, chances are the timing cover can be drilled to take both the fuel pump and front-mounted dipstick. If this is the case, swap eccentics and your in business.
ratio411
3,870
73
109
Pensacola FL
Sep 16, 2007
  • Sep 16, 2007
I would use a Wieand Stealth and Holley myself.
Much better stuff than the Federal Mogul carb that Edelbrock boxes up.
You need a timing cover from an older SBF with a fuel pump, proper timing pointer location, and dipstick provision. Any 289/302 that is correct for your model car will work. You may need to swap to the balancer and pulleys for your year model too.
That way you have the correct timing marks, and accessory placement. Oh, and the correct water pump...
The 97 distributor won't work.
You need an early points or Duraspark off a Windsor.
Personally, I would use a Duraspark triggering an MSD instead of the factory box.
If you find a points unit, swap in a Pertronix 1.
Use the steel gear from the 97 distributor if you keep the roller cam.
On the emission ports in back of the heads:
Cut off the pipes from the blocks that bolt to the heads, then swap them side to side, turned upside-down, then they become their own block off plates. Use new gaskets.
You need a Windsor oil pan from any front sump car.
289/302 exhaust will usually work.
I have also had good luck using SBF brackets on 351s.
Power steering can be hit and miss.
Never swapped AC...
Dave
Edit:
Always change the oil pump.
A regular flow pump is cool.
If you really must use an HV pump, use an aftermarket upgrade pump driveshaft.
I use the high strength driveshaft even with a regular pump.
HV pumps are over rated and suck HP away.
Check the valve springs too.
Springs and valve umbrellas are real easy to swap when the engine is out and should be done on an engine with some miles.
Will make you much happier than dealing with a used engine that smokes badly or has weak springs.
If the engine came in a truck originally, it will have a good roller timing chain. If it is out of a car, it will likely have the plastic upper gear, which is junk.
The thing I don't know is if you can even use a mechanical pump with the stock timing gear set.
You will need to find a fuel pump eccentric that will mate with the cam, cam retainer, and timing set. Use caution here! The wrong parts mix matched are not a good thing!
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
