Hi guys,
I think it is time for my engine to have an upgrade.. The current combo is:
-Edelbrock 600 cfm carb
-Edelbrock performer intake
-Crower mechanical cam 212/216 lift around ,480
-Stock -69 heads with Screw in studs, guideplates, 1,6 alu-rollers
-Hedman shortie Swapheaders 1 5/8 and 2 1/2" pipes with H
-Mallory Unilite and Hyfire coil
-69 stock block, bored 030, sitting 1" lower than stock
-stock 4bbl bottom end with ARP bolts, 10:0?
-Toploader 4-speed
-8" with 3:00 gears
Car is run every day on street and sees some cornering tracktime.
What I was thinking of :
-Porting the stock heads (Inspection guys don´t let me change them to AFR´s), bigger valves 1,9/1,6(or 1,5)
-750 carb, Performer RPM / WeiandStealth, and a rougher cam matching these intakes. I don´t think I can even fit Airgap there under the hood...
Is changing to RPM intake killing my bottom end torque ( the car is -66 coupe weighting 2920lbs)?
Can the stock bottom end with ARP bolts handle 6000 rpm, and for how long(10000 miles?).
Cam suggestions? I need pwoer from 2000-6000, peak 3500-4000
Do I need to invest on 9" rear.. Wouldn´t like to(weight, cost, just rebuild 8")?
Thanks for any info...
-Toploader 4-speed
-8" with 3:00 gears
