Progress Thread 351w stroker rotating assembly and build
  • Thread starter Thread starter Ric4eyedFox
  • Start date Start date Mar 23, 2025
  • Tags Tags
    351w stroker. 408 . procomp heads 210cc 351w
R
Ric4eyedFox
Houston
Mar 23, 2025
  • Mar 23, 2025
I have a 1996 351w roller.
I came across a eagle crank shaft .( 4”stroke 4340 forged) from an individual on Facebook for a good price. I ended up buying it. I’m having trouble on choosing brands on the rest of the rotating assembly. I plan on going .030 over. Although the block looks in very good shape right now.. should I just go l eagle with the rods and pistons ? Should I keep stock bore ? . Im lost and what cam to get as well… I Also have 210cc pro comp aluminum heads and a tremec tkx transmission.. I will want to turbo in the future but as of now I would be very happy with a 500 -550hp car. Im building this in my 83 coupe
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Mar 23, 2025
  • Mar 23, 2025
Have you chosen the shop that's going to do the machine work?
I would let them look the block over and help you decide from there.
Reactions: General karthief and Ric4eyedFox
R
Ric4eyedFox
Houston
Mar 23, 2025
  • Mar 23, 2025
Yes I dropped the block off at the local machine shop to get cleaned. I will ask him. Tomorrow
R
Ric4eyedFox
Houston
Mar 23, 2025
  • Mar 23, 2025
does anybody have any personal experience or personally know somebody with the 210cc Procomp heads?? If so please share experience thank you..
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Mar 23, 2025
  • Mar 23, 2025
Nice. Once the bores are all measured you can figure out if you need to go over.
Reactions: Ric4eyedFox
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Mar 23, 2025
  • Mar 23, 2025
I moved this in here since it's for the same build.
Procomp are Chinese knock-offs. The castings seem to be 'ok'. I've seen some folks return them for other castings and some build them up and they work just fine.
R
Ric4eyedFox
Houston
Mar 23, 2025
  • Mar 23, 2025
That’s for the advice. If the bores all look good stick to the stock bore
thanks for moving it.. I am new here and still trying to figure out how to navigate thru this page. I unfortunately bought some used ones on Facebook marketplace .. not knowing too much about them. I just saw 210cc and jumped up quickly.And now I am worried about dropping a valve after I invest in forged rods and pistons..
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Mar 23, 2025
  • Mar 23, 2025
Drop them off to the same machine shop that has your block. They can look those over too and probably advise you on springs and cam to go with your pistons and rods.
R
Ric4eyedFox
Houston
Mar 23, 2025
  • Mar 23, 2025
I will do that tomorrow. Thanks for the advice
AeroCoupe
6,258
4,341
183
Claremore, OK
Mar 24, 2025
#10
  • Mar 24, 2025
  • #10
Good valves and valve train parts will keep that valve right where it needs to be. I had one of the valves that came with my AFR 185's come apart and smoke the motor which lead me to buying bare heads and having the gentleman that builds my motors put the heads together with good parts as well. Not saying all assembled heads have junk parts but they are doing everything they can to keep prices down to compete with the offshore stuff.
Blackhawkxx
Stroke it!!!!!!!!!!!!
Mar 3, 2023
584
581
103
Mar 24, 2025
#11
  • Mar 24, 2025
  • #11
I have always heard one of the reasons to go with AFR is their high quality parts. Was yours a one off or have you heard from others the same?
AeroCoupe
6,258
4,341
183
Claremore, OK
Mar 24, 2025
#12
  • Mar 24, 2025
  • #12
I have one of the first sets of the 185’s from back in 1998-1999 so a lot has changed with them since then i.e. got better. Just saying that due to that I just get bare castings and build them out with what l know are quality parts.
Reactions: Blackhawkxx and Noobz347
R
Ric4eyedFox
Houston
Mar 24, 2025
#13
  • Mar 24, 2025
  • #13
That makes sense
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Mar 24, 2025
#14
  • Mar 24, 2025
  • #14
AFR [used] to be all hands-on with their stuff. Nothing went anywhere without a bunch of motor-heads snooping all over it, first.
I don't know that [anybody] is that way anymore. All those man-hours means the Chinese are under-selling you. They play the averages and send whatever is on-deck, out the door. Sure, some come back but what do they care? They're playing the percentage. You'll have to jump through hoops, pay half the shipping, etc.. and so on, if you ever want to see your engine make "Vroom".
So... I whole-heartedly agree with what AeroCoupe is saying:
Get the castings (have them checked out)
Get your parts (and have them all checked out)
Because these steps are skipped by most manufacturers/vendors that deal with us Riff-Raff John-Q Public types.
Reactions: Ric4eyedFox, AeroCoupe and General karthief
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
P
New to StangNET
  • Popeye1790
  • Apr 19, 2024
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2024
Popeye1790
P
A
351w build looking for help.
  • Ang3lgarcia
  • Jan 19, 2022
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 23, 2022
96pushrod
