What do you guys think about stroking a '69 351W to 427? The engine will be put in my '70 Mach 1. Any dangers? What modifications will I need to make to the block? What extra parts will I need? Thanks.
Yeah, I've thought about it a bit... I've seen that they can flow decently, but they'll never be as good as a set of newer aftermarket heads that have the advantage of 3 decades of technical development and engineering. Still, if you want a way to compare flow numbers on some popular heads, check out http://www.jason.fletcher.net/tech/flowdata/castiron.htmwickedmach1 said:DarkBuddha,
I was happy to hear you are thinking about using '70 351W heads. I hear a bunch of people say they aren't worth nothing and won't flow good. What's the deal? I have a set that I was going to use. I completed a port match myself and removed the humps. I was thinking about getting them professionally ported. When is it not worth investing the money in the heads and deciding to go with aftermarket cast heads. Thanks for your help.
