Started the 354 tonight, the chip JMS burned worked great, fired right off, no surge, smooth idle, no hesitation, no CEL. ...at first... then I got a CEL. at 2500 rpm you could tell something wasn't right, a miss. Checked spark with test light while running, every cylinder was firing. Checked signal to injectors, all getting power. Pulled #5 plug(cold header pipe) plug was as clean as when it was installed, NO FUEL. Looks like I have a bad 30lb injector
Bought them new from parkway ford, frpp brand. My builder said he has seen it happen before, new injectors that come with a flow sheet that don't work! Anybody had a similar experience with Frpp injectors that were bad from the factory?
