3650 to t5 questions
Just a question...
Why go from a stronger transmission to a fairly bit weaker transmission?
By the time you had the correct parts to swap it over you could likely build a stout T-3650.
No there isn't...at least not a ready made one.
The T-5 only bolts up to the 302 and V6 engine. You would need a custom setup to put one behind a 4.6L
But the 3650 is a stronger trans. Even though the t-5 is a better shifting trans, it wouldn't stand up to the 4.6L over time.
I would take a T5 over any other 5spd trans any day. The T5 trans comes off the bell housing and in your hands in under 30 minutes. If you have a problem, it is easy to remove, fix, and reinstall. And with all the new HD parts they make for that T5, you won't be taking it out after you put a good one in. The damn T45 and TR3650's don't have the removeable bell from the outside, making removal of them a nightmare. The only good thing about them is that if you have a problem with 5th or reverse, it can be fixed while still in the car, because you can just remove the rear tail housing and 5th and reverse is seperate.
I have had trouble with clutches not disengaging on both T45's I have had...which is almost the same as a TR3650.
I have had problems with three T45's...(2 in my Cobra) and (1 in my 81 notch which I just had fixed)
Those transmissions have caused me nothing but headaches, and I have not one bad thing to say about a T5. I know I don't run 10's with them, but the cars I have had with T5's have ran low 13's and seen heavy street abuse and tire smoking action.
