393 budget buildup
Smaug
157
Nova Scotia
I am in the very early stages of planning and building up a 393 stroker.
Anyone one here gone throught this process that could provide a little feedback on any dos and donts you may have come across? Anyone done this one a fuel injected 351?
I have a 351w complete engine now, and im looking at picking up a 2000 explorer engine to rob the heads and intakes - i understand that these would be the gt40p heads?
Anyways, looking forward to some advice.
Thanks,
Steve
you can pick up a stroker crank for about $200 from competition products. use a set of stock 351w rods and stock replacement 302 pistons, flattops are best. for heads you can pick up a pair of windsor sr heads bare, and get the valves from competition products, as well as the valve springs retainers and keepers and end up with a complete set of heads for less than you would for a complete set of heads. as for a cam, figuring that you want to run on the street, and since you are adding cubes, you can run a cam like the 282xe cam from comp cams. you want a set of headers with a 1 5/8" primary tube and a 3" collector. for an intake i would use a weiand stealth topped with a 750 carb, kind of small i know but for the street you dont need more than that. this combo should make about 400-425hp, and work real well in the 1500-5500 rpm range. the torque curve will be fat and flat which is what you want from a street engine, and it will have a monster amount of torque.
