393 finally done, won't start!!
5.8CAPRI
58
Lake Stevens, WA
Alright, I need some of your guys expert advice here. After about 4 years, and roughly $7,000(I lost track) my 393 is done, and in the car. :D Get everything hooked up, plugged in, and go to fire it up, and nothing. It coughs every now and then, but that is it. I have checked compression, which is about 150. It would appear that I have spark, I pulled the intake off, removed the fuel rail, and lowered my fuel pressure, then pulled the dist and hand cranked it to make sure the injectors are firing, and they are. I have even tried starting fluid, and nothing. Only a few coughs occasionally. :shrug: I don't even know where to go next. The following is a short list of the motor. And thanks for any help or ideas.
351w block
Ported Edelbrock Vic Jr 70cc hds
Scat stroker crank.
Stock truck rods shotpeened and smoothed
main girdle
ARP everything internal
Head studs
Triple layer head gaskets
Comp cam XE282 roller retrofit cam
Roller rockers
TFS Intake
30lb inj
BBK 75mm TB
75mm PRO-M MAF
MSD billet distributor
stock coil
Stock computer
BBK ceramic coated longtubes
and a bunch of other knick knacks
So with that in mind, Ideas? Oh yeah, one other lousy tidbit, I sold my house and have 14 days left to be moved out.
Jrichker's 'Cranks but wont start' checklist could help.
Based upon what you said, I have two thoughts (I am not there with you, so take them as you may).
I would confirm that you do have spark, for sure.
And are you real sure you have the dizzy stabbed on the compression stroke? It almost sounds like you are 180* out.
Good luck.
Yea I agree, I did the 180 off with my dizzy when i did my motor, actually i put it so cylinder 5 was #1, but thats what u get for working on it 13 hours straight lol, since u said u tried starting fluid and didnt start, i would say its def. a timing issue...restab the distributor and make sure u have the right firing order
Thats sound more like it than timing being a little ways off.
If the firing order is off by a cylinder,and the timing is whacked,it usually ends up in a big back fire.
Like said,re stab the dizzy,check firing order....and make sure that you or a buddy can ready exactly were TDC is on the balancer :)
Thanks for the tips so far. I have only checked for TDC once, while the motor was out, and left it there unitl I stabbed the dist. I have also tried 180 out, and got a few more coughs, and one thorugh the intake. so I put it back. I have checked the firing order more times than rainy days in Washington. Then once more. I agree though, still sounds like a timing issue. I will try the TDC thing based off #1 hole again tomarrow. I have even tried flushing the gas in the tank to no avail. When I pull the plug wire, I get a good solid spark, but that is no guarantee that it is firing under pressure. I have also tried a timing light on the coil, and #1 while cranking and get good light pulses. And the longblock was assembled by a competent local engine shop. Good start though, keep em comin!!:nice:
PS- Anyone have the link for the crank won't start list? I tried a search and couldnt find it by title or user. Thanks
As requested...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
are you using the HO firing order. 13726542. if so and no crank, swap the wires directly across the dizzy with the corresponding wire and try that. if it cranks, it is 180 out. i just went through the same thing and i was sure it was not that but it was.
BTW I wouldnt line it to TDC Just by using the balancer and timing pointer. Once you find the the #1compression stroke(either by looking at the rockers or feeling for compression by putting ur finger or piece of rag in the spark plug hole and it will pop out), take out the #1 spark plug and stick a screwdriver in the hole and so its touching the top of the piston and rotate the motor until the screwdriver is all the way at the top of its travel. That will be TDC, then u can remark the balancer if u need to, and then you can restab the distributor to that.
IT'S ALIVE!! :D :D Thanks to all for the help. I think I had a few malodies to start with, but ulitmately it was indeed the DIST 180 out. She don't idle for beans, but that is to be expected at this level of mods. ust need to get'er chassis tuned now. Not getting a check engine light, so must not be anything too serious wrong. But man, I aint been that pumped since my daughter was born. Thanks again :nice: I look forward to being able to post some numbers and pics down the road. :nice:
