I have a PA Performance 3G upgrade on my car, using their wiring kit as well. My car still acts about like a stock alt when you have the lights/radio on etc. At idle the lights will dim and when you rev it up, they will get brighter. This annoys me to no end and I want to fix it. How much output should one have at idle? I do have a underdrive crank pulley on the car(will be changing out to stock crank pulley when A/C goes back on the car). Is that crank pulley causing the alt to turn that much slower that its causing this to happen? The PA Performance 3G alts are "supposed" to put out more power than the stock alts as well based on their website. How much volts should I be seeing at idle and where is the best place to measure it at? Thanks!
