3G Alternator & Idle Problems
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
I've post about this before but I have a more specific question this time. I put in a 3G alt several months after I purchased my car because of the stereo equipment I planned to install. When I did the job I had little experiance with turning a wrench so I bumbled my way through the process. In the end I got it installed and everything ran so I left it at that. It seemed to charge great when it was cold but as it warmed up the charge needle would start to dip below the large tick on the guage. At running temp the needle would get down to one or two ticks above the red zone and bounce around a lot with the idle. I was expecting better performance considering the only drainage I added to the system was a set of 10" woofers with a 300W amp (no electric fan, stock fuel pump, etc...) Now Ive been having idle problems for quite some time, searching idle, wants to die at start-up, that kind of stuff. I've gone through almost all of the suggestions in the Idle Sticky with little success, could the stock power and ground wiring be my problem or should I start replacing stuff like the TPS and Salt and Pepper shakers? BTW what kind of charge SHOULD I be getting with this 130A alt? Should it be pegged out all the time considering I only have a stereo to draw extra power? Thanks for the input fellas. :nice:
::EDIT:: In case you didnt catch the drift, I never put in the 4guage wire that people suggest. I just cut the wires at the connector and spliced them into the 3g connectors.
Put on your flame suit :)
This should be THE FIRST thing you do. Install it with the correct wire. After that I would check the grounds. My gauge bounces with the idle when I first start it but after it gets warmed up it's fine. The gauge is going to bounce if it's idle hunting. When you are driving though you should see a nice steady charge. Mine with only an electric fan sits right on the line above the middle.
Yeah I figured Id catch some flack but it was time to nut up and ask, this idle problem is pissing me off. BTW the alt charges fine when the rpm's are up, i.e. driving, its just at idle I have the problems. Theres nothing quite so annoying as watching your headlights pulse with your idle :bang:
The reason your amp meter falls as the temperature of the engine climbs is simple. Those factory wires that run between the alternator and battery become heat soaked (from the engine and the current) and can no longer pass electricity. Sooner or later those wires will get hot enough to start a fire in the engine compartment. You need a flame suit to save your life, not for the forum. Upgrade those wires!
This is the wire that needs to be upgraded to a 4 guage? This is the ground wire right??? What about the positive lead wires? There are two of them (smallish, maybe 10 guage?) are they both replaced by one 4 guage? Im confused...
Yep, upgrade the wiring and power ground and see where you stand. The stock wiring is good for about 55 amps - my aftermarket 3G puts more than that out at idle.
It should take about 30 mins to do the wiring so get it done and go from there. That will remove one variable.
Also, how low is your idle setting? If too low, the alt might not be spooling up enough to have decent output. There is a magic spot between 600 and 700 RPM on many alts (where at 600, the output sucks and by 700 it is good).
Good luck.
In your pic, that lug on the alternator is for the 12 volt cable (that goes to the starter solenoid)! The new cable you run will REPLACE the stock 10 AWG cables. If you dont have the wiring upgraded, those two little cables should be attached to that lug (perhaps you spliced in a short strip of larger cable for fitment).
The alt is grounded via its case (which is why I said to upgrade the motor ground - that is a tip from Jrichker).
I would read JR's newer post about alternator upgrading. His parts list is great for the wiring and he explains it all very clearly.
Good luck.
Prefab 4 gauge wiring with lugs already attached can be found in the electrical parts area of most auto parts stores. Use some string to lay out the cable routing and determine the length.
To do your own custom cable setup, here are the parts:
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
Don’t forget the alternator power ground!!!
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
Hmmm....its been a looooooong time since I checked out that wiring, I dont know what I was thinking. I completely forgot how bad that thing is jerry rigged together, out of sight out of mind I guess. I guess my question is there are two connectors on the 3g, the small connector with the white wire /w black stripe goes to the main connector, then two wires run off the main connector: (sorry for the blurry shots)
How do these two wires transition into a 4g wire??? Each wire is a 5th the size of the 4g, how does that work?
Right now the two wires (Green and Yellow) are spliced into the two old black wires /w orange stripes:
Here is the condition of the "splice"....nice huh? I know Im a dumb ass...oh well, nothing caught on fire.
So what should I do from here...just pull everything and start over?:shrug:
The original small plug (the one that does NOT contain the stock charge cables) on your stock alternator should have plugged right into the 3G as I recall.
I would take a look at the two sites JR often links folks to - Monte Smith's and Mustang central. The latter's pics will help.
Good luck man.
The alt I got came with the ford conversion plug (with the integrated stator wire/plug). It came with simplistic instructions that said to clip all the wires off the old plug and splice them into the supplied plug...:Damnit: Leave it to me to make an easy job hard.
OMG MAN do not run your car with the wires like that.. they already have almost started on fire. wow you are lucky a lil more burn through on those wires and your engine bay would be up in smoke.
The really sad thing about it is that Ive been running the car like that for over a year. Its not my daily driver so I think thats why Ive gotten away with it for so long. I think I've got my head wrapped around the wire install now. From what I understand when its all said and done I'll have the 4g wire & the 12v starter silanoid wire attached to the lug on the alt stud. Is that correct?
I would not do it that way. Should your 4 AWG cable fail (blown fuse, bad connection, etc) then you are running mega amps through the stock cable.
What you do end up with is the 2 stock cables taped up really really well and tucked away at the alternator side. But on the starter solenoid side, you leave the stock wire connected (that is why the other end is so well taped up). This retains the switch and sense wiring so the alternator works.
Cool?
Ahhh I see now...thats a little counter intuitive. I just assumed the 4g wire would attach to the alt directly at some point...thanks Hissen that really helps. So just cap off the black /w orange stripe wires at the alt and leave them at the starter silanoid. :SNSign:
::EDIT:: Just curious what are the two Green and Yellow wires that come off the D plug for?
Wait, the 4 gauge cable does connect directly to the alternator. On the alternator, the only power cable connection you will have is the 4 gauge cable. This cable runs alone to the starter solenoid.
The big connector that has the stock orange power cables is: dont plug that connector into anything at the alternator. You will splice into the stator wire but that is all.
So now you have the stock big connector set aside (the stock power cables are not connected to the alternator). But that is all you do with the stock power cables. You dont have to disconnect them from the solenoid or anything (in fact, you dont want to).
Good luck.
Now Im wondering how the car ever started in the first place :shrug:
I think we're square now, but what are these two wires for that come off the D-plug on the back of the alternator:
Green wire /w red stripe, Yellow wire /w brown stripe? These are the wires that are burned in this splice:
