  • SN95 4.6L Mustang Tech
3rd gear problems help!!!
  • Thread starter Thread starter minniegreyv8
  • Start date Start date Feb 7, 2004
M
minniegreyv8
53
Bay Area CA
Feb 7, 2004
  • Feb 7, 2004
its getting difficult to put it into 3rd gear...causes a slight grind at lower speeds, and if im trying to downshift on the highway at about 75mph it's almost impossible...huge grinding. whats going on???
37k on my 01 gt
M
minniegreyv8
53
Bay Area CA
Feb 7, 2004
  • Feb 7, 2004
bump
Beau
3,050
San Diego
Feb 7, 2004
  • Feb 7, 2004
are you pushing the clutch in all the way? are you sure you're shifting right into the 3rd gear slot?
M
MacDiesel
74
  • Feb 7, 2004
37k on my 01 gt
i have had a couple of stock trannys do that to me. that is the first sign that the synchronizers are going out. time for a new tranny.
StangLou
1,264
Holly Springs, NC
Feb 7, 2004
  • Feb 7, 2004
Mines a little tough to get into 3rd from 5th when Im over 75 or so. It has every right to be IMO though . Try rev matching it and see if that will help you stick it in 3rd easier. If not, try putting the clutch in, holding it there for a few seconds, then downshift. Maybe your synchros just arent lining up as quickly as they should
Hope this helps
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
