Bill if your out there or anyone else.
Have you found a good solution for the VCT? did you engineer a component that actually simulates the VCT? i read somewhere that if you install the timing chain 1 tooth off that will retard the timing 17 degrees and that is a simple compromise so the VCT won't be stuck at fully advanced. what is the best/easiest solution?
How did you convert the electronic throttle body to mechanical?
How did you convert the electronic TPS to mechanical?
do the stock compents just bolt on?
is there a company that manufactures full length headers for the 3v that fit the 96'-98'?
who has the best P/P job for 3v's? livernois? fox lake?
which cam are available for the 5.4? will the 4.6 3v cams work just as well or better/worse in the 5.4?
where can i get that 3/4" adapter for the intake so my stock upper will bolt right up?
does the t-45 or TKO just bolt right up to the 5.4 3v? stock bell housing will work no problem? just change the flywheel and clutch assembly?
-jp
-jp
I feel like I need a crash course in modular motor speak.
