APowers
Ok I can see how your "light to light " improved. But you traded top end. Explain to me how this is better. I am not trying to sound dumb, but what was the advantage to the trade off?
APowers said:Ok I can see how your "light to light " improved. But you traded top end. Explain to me how this is better. I am not trying to sound dumb, but what was the advantage to the trade off?
FL2005GT said:sacrstang said:I remember when I picked the car up after they were installed. I almost spun out leaving the parking lot. I was testing it outQUOTE]
I'm planning on 4.10's. I also plan to go with some wider, stickier rubber on the stock 17"X8" rims so I can hook up. I have a 5-speed GT.
Do you all think 275 (the widest you can really put on an 8" rim) 45 ZR-17's, in a summer tire, would work? Maybe even 255 45 ZR-17's?
I was told by the wheel company and Les Schwab that I should stick to the 275s with the size wheel I have. I was pushing for 295s initially. I was pretty happy with the way they looked once they put the rubber on.
welchy said:What rpms do you run at freeway speeds with 4.10 or 3.73 gears?
seattlegt said:wish 93 octane was available in WA
projp said:Hello everyone.
I've been around for a little while, mainly looking for tech items re. putting an 89 5.0 in my 74 Bronco.
I picked up my 07 GT yesterday, (5 weeks from order date), and am now looking at tweeking it a little.
I understand low gears, (the Bronc has 4.56's), my question is how much more rowing through the gears is involved with the gear swap? Is it very noticable?
First already seems pretty low to me. If I am not redlining every time am I going to wish for taller gears for normal driving?
I like a peppier car like everyone else, but most of the time I am just driving, not racing.
jberylec said:Do you have a manual or automatic? If automatic, go with 3.73 gears, better match for the gearing in the auto trans.
PDXStangDude said:Fast Specialties on Minnehaha IIRC.
Bullitt2343 said:Please explain before I purchase the gears for the automatic Roush. I have always read tec articles the rule of thumb was to gear one step lower for a auto like 4:10's vs the 3.7 or 3.9 that would be used for a stick. Is it not the rule in this case or maybe things have changed because the new generation auto's have different gearing?
Thanks,![]()
Bullitt2343 said:I would advise you get a quote from Jeff at All Ford Performance also in Vancouver, he did the install of my 3.73's in my Bullitt for much cheaper then Fast has quoted you including parts, oil and speedcal.
I will be a return customer real soon to regear the '06 Roush
