  • SN95 4.6L Mustang Tech
4.30's or 4.10's?
  • Thread starter Thread starter stangnutlx
  • Start date Start date Dec 4, 2008
First Prev 2 of 2
BurningRubber
1,865
24
58
Dec 5, 2008
#21
  • Dec 5, 2008
  • #21
squeak93 said:
Thats not accurate at all. On my 04 I had, 4.30 gears, 26 inch tire, 108 is where I hit the factory limiter in fourth. (5 speed car). So you can get well above 100mph with 4.30s. Just don't plan on any real power adders.... maybe a small shot of n2o.
Well, I stand corrected then.
My speedo must be off or something even though it's calibrated... on a 315/35/17 4th ends right around 108-110mph according to my speedometer. I figured that would be around (give or take a few) 100mph with 4.30's.
Mustang92 said:
x2
26" tire, 4.30 gear in 4th gear will top out at 108-109 MPH.
26" tire, 4.10 gear in 4th gear will top out at 114 MPH.
Bill
What is 4th good untill with a 28" tire and the stock limiter? That is what size drag radials I have (they are overkill, but they were free) and I figured I might get 114-115mph out of them, but it looks like I might be in luck in case I run nitrous.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 5, 2008
#22
  • Dec 5, 2008
  • #22
4.10s not that much difference and the 4.30s require a modified cross pin that is weaker than the stock one and cost another 35-45 bucks
squeak93
2,356
419
164
Joplin, Missouri
Dec 5, 2008
#23
  • Dec 5, 2008
  • #23
Sorry, wasn't trying to call u out there. Just wanted the op to get accurate info to make their decision. I actually wished for quite a while I did 4.10's instead of 30's. The 30s seem to cause the coveted low end buck while trying to cruise parking lots. I imagine on a stock type car u won't see much if any gains in the 1/4. Takes on heck of a driver mod to pull either off on street tires.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Dec 5, 2008
#24
  • Dec 5, 2008
  • #24
28" tire, 4.10s, stock limiter would be 125MPH in 4th.
I haven't been able to get it hosted on my site but if you want I have a RPM/Speed calculator (excel file) that I can email it to you. Basically it allows you to put in tire size, transmission, rev limit and gear and it shows you the speed, RPM by gear ratio. It's also good to figure out the differences in cruising speeds from changing gears. Email me at mustang92@hotmail.com and I can send it.
Bill
stangnutlx
242
Coventry, RI
Dec 5, 2008
#25
  • Dec 5, 2008
  • #25
How tall is a 315/35/17 tire?
BurningRubber
1,865
24
58
Dec 5, 2008
#26
  • Dec 5, 2008
  • #26
It's no problem, didn't take it as you were calling me out...
I get a little of the low end buck with 4.10's too, but it's not too bad.
I like the 4.10's for the track, but on street tires I have only managed a low 2.1x 60' so I know what you mean about it being hard to pull it off on street tires.
Drag radials make it so much easier, lol.
Bill
Awesome, thanks Bill.
I'll send you an e-mail so I can get the calc. from you.
Each brand may vary a little, but my Sumitumo HTR-Z's are 25.7" overall diameter in that size according to Tire Rack.
fast97gt
1,082
north carolina
Dec 5, 2008
#27
  • Dec 5, 2008
  • #27
dude 4.10s are they way to go, i notice with mine 1st gear dissapears quick. i'd hate to see what 4.30s do.
First Prev 2 of 2
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
