4.6 go fast mods
powermaxx
168
melfort, sk
hey i just baought a 98 4.6L ford flairside and i need some mods that will give quick hp increase. is the truck 98 engine similar to a 98 mustang or is it mor like a 99? what type of products are out there for some bolt on hp i was thinking of a cam throttle body and supercharger. would like to have this baby in the 14s
Those trucks arent light man, id say forced induction is gonna be your freind in this case.
There was a guy with a bunch of videos of his N/A F-150 running into the 14's if I remember correctly. However, I dont remember if it was a 4.6 or 5.4. Try to find them on www.videos.streetfire.net. It can be done, but its gonna cost alot of money.
As far as the engine, it shouldnt have the PI heads on it. If I remember right, they made right around 235-240 hp or so in the trucks.
In 98' the F150 was rated at 210hp. I wouldn't recommend doing the PI headswap if you're planning on a S/C later on.
Well, weve got 2 cams in our engines... just makes it more expensive...:(
If you are going forced induction, be careful with what kind of cam you choose. Some are blower freindly, some not.
If you can afford all of these mods including a supercharger, then you should have just bought a Lightning in the first place. Sell this truck and buy a Lightning.
the 4.6 mod motor's really don't response to bolt on's like the old trusty 5.0's did.
If seeing serious drop in et is your goal. Power adders are your friend. I'd think about a turbo setup on there but that's me tons of room in the engine bay no-one would expect it.
Nitrous will get a good drop in the et but filling bottles gets old. :( oh well still cheaper than a blower and I outrun the blower cars I know :)
Blower - Kb's are good choices the power rigth then is nice prolly won't need much gear to have fun in it.
what parts will i need to get this 4.6 to 320hp on all motor? so far for boltons i should get electric fans, chip, pullies, throttle body, mass air, PI head swap (maybe), headers, and kenne bell at 9psi with 4:11 gears, and msd.
what kind of mods have you guys been doing to your 4.6 96-98 mustangs? what hp and et's do you get?
Umm Kb makes it a power adder and I hope that it'd be over 320hp. :D
To hit the 300RWHP level N/A . Cams (aftermarket and since you aren't sure yet on overall plan I'd go with the comp 270's and springs), all the bolt on's, Full exhaust, and a good tune and maybe a set of Ported Pi heads.
madmatt said:
Nitrous. That or a PI headswap and even then, thats a LOT of weight to push into the 14's man.
So true. I have a 97 4X4 F150 short cab/flareside, 4.6/5 spd. I love the truck but it is HEAVY. I couldn't imagine this thing with an automatic. You need a lot of low-end torque (unlike a lighter Stang) to move that beast around quickly and the 4.6 isn't known for low-end torque. I doubt your king cab is much lighter, so I would recommend a supercharger and gears. I tried some mods like a 93 octane tune, CAI, cat-back and it just didn't do much. For starters I would do a flow-through cat-back (like Magnaflows), install a K&N air filter and remove the silencer. Good luck just going "all engine", I am still curious if it works for you, though.
Read my sig below for my Mustang mods.
powermaxx said:
what parts should i start buying?
I've pretty much done it all to a 96 4.6 Mustang GT. Here's a good place to start. http://www.themustangshop.ca/site/cat_explore.php?c=680&Method=Category
They're in Calgary. I sold a my set of stock 2004 Mustang GT cams to a friend with a 98 F150 with the 4.6. He was really happy with the results. Said it really helped gain power. Easy place to start and the cams are cheap. I just bought another set of 04 GT cams off e-bay for $70 just in case I need them sometime.
