4.6 stroker advice
cobra vodan
12
Utah
Hey guys! I just found this site and I'm hoping you can help me out. I'm looking at my next big round of mods and I'm trying to decide if I should go with a stroker kit or just a stock displacement forged bottom end. If you have any experience/ advice I would love to hear it:nice:
Here's my current set-up:
1996 Cobra
2.2 kenne bell @ 10 psi
o/r x-pipe and magnapacks
255 lph bbk fuel pump
42 # injectors
FRPP 4.10's
MGW short throw
+ some visual stuff.
When I do the engine rebuild I'm also planning on the following:
centerforce clutch
Billet steel flywheel
dual core aluminum radiator
Meth injection
Kenne bell 12x4" intake filter
FRPP 9mm wires
wideband AFR
lots of guages
14-15# blower pulley
That's about it. Sorry for the long post. I appreciate any help. Also, if you have a suggestion for a good throttle body and MAF that would be great:nice:
For one, the geometry of the engine goes to crap when you stroke it. The 4.6 is pretty much square, so when you stroke it, you end up with a longer stroke than a bore diameter and that's not ideal for making power. Of course, the 5.0 stroker won't be as bad as a stock 5.4. ;)
Also, it tends to put the piston pin into the ring pack, and the ring pack too high on the piston for durability. I don't know if this is a problem on the 4.6, but these are things to consider.
Thanks for the input guys :nice: What MAF and throttle body would you recommend? Also, where would you get the forged rotating assembly? I've been looking at the kits from Livernois and Summit...
Thanks again:nice:
I've been running a Moduar Powerhouse billet stroker shortblock for 3 years with no problems. I went 9.8 with a 2.2 KB and 9.4 with a 2.8 KB. As far as I'm concerned, every little bit helps. I think the stroker is worth about 30 rwhp across the board.
IF IT WAS WORTH 30 HP ACROSS THE BOARD, I WOULD HAVE DONE IT...THATS A LOT. however, my builder told me that he only sees about 10 rwph withy the stroker. i dont know what is right here but i think it might have helped the bottom eend of a centri power adder car. for the kb blower i wouldnt bother.
N/A, Strokers have been shown to lose about 15 RWHP when using stock heads, cams, intake manifold and the stock compression ratio. In N/A form, they never gain it back.
Now FI cars are a little different. Throw enough boost at them, they will overcome the stock displacement and make more power. I would never put a stroker in my cars however if I did, it would be with a positive displaced blower like a Kenne Bell.
That 30hp is with a blower kit. Either way, the big bore will result in better gains.
So I would be looking at roughly a 30 hp gain with the stroker? Who sells a big bore kit and about what kind of gain do you think that will give? Also, in case you want to know I'm dropping the compression to about 8.5:1.
There is not a lot of places that do Big-Bores. You can get them from Ford Racing, Modular Performance or Renegade Racing.
N/A, the Big-Bore gains 30 RWHP with the stock heads, cams, intake manifold and stock compression over the stock 4.6L. When you start adding parts, the Big-Bore shows better gains than the 4.6L. You could see well over a 100 RWHP gain with a Big-Bore and FI.
I have a N/A Big-Bore and I will say they are not cheap. You are looking at about $1200.00 more to have a Big-Bore than a stock displaced engine and about a $1000.00 more than a Stroker.
