- Jan 7, 2003
- 156
- 1
- 18
I changed my original pump because i thought is was going bad. I later found out that the pump is leaking from the bottom. I took the new pump and changed the O ring and its still leaking.....WTF
RandyStinchcomb said:did you buy a Ford O-ring (FIVY-8507-A) or something from a parts store? maybe you rolled the o-ring over on itself?
foncarelli said:No, i didnt. I need to order that O ring from you and a belt tensioner.
DropTopPony said:have you checked to make sure its not your intake cracked and leaking down the front...just a thought.
foncarelli said:There are no signs of coolant anywhere above the pump.
RandyStinchcomb said:or you could try some coolant system tracer dye, have some if you need it.
