You gotta match up the engine, trans and o2 sensor harness to the year of the car. Since yours is a 1993, you need a 1993 v8 engine harness. I also beleove 91-92 is compatible with 1993, but not 100% sure. Ford changed the plugs for the engine harness to dash harness a few times.
If you are putting in a manual trans, you need the 5-spd trans harness that runs from drivers kick panel to trans hump and then through the floor. If your 4-banger is already a stick, you have this already. If making an automatic, you can use either.
Also, you will need o2 sensor harness from a 90-93 v8 car. There are two. One for auto, one for manual trans. Get the one that matches your trans.
For computer, 89-93 is mass air, so since you need a mass air engine harness, you need a mass air computer. 89-93 will work...again, get the computer that matches your transmission.
You really need to be consist end with your trans choice. Mixing and matching auto trans and manual trans harnesses can lead to bad things.
Also, I'm sure you know you need to change the trans, relocate brake like on pass side of car and other supporting mods like upgrading brakes and suspension and such. The rear end can wait a little while, but if you do the swap and hammer on it right away...it will snap like a twig
