4-banger transmission...
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Nov 11, 2005
90mustangfan
93
So cal
Nov 11, 2005
  • Nov 11, 2005
I found a 4-banger trans for my car at the junkyard for cheap...And my T-5 trans is basicly shot. will 4 banger tras hold up to the amount of power im making with 4.30 gears...can it handle the power? what will I need for the swap I heard some kind of 8 tooth spline or something..IDK
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Nov 11, 2005
  • Nov 11, 2005
No.
BTW, try a search for this topic...there are hundreds of threads about this, including the pilot bearing part number that you'll need to make it work.
jackchan
507
Mobile Alabama
Nov 11, 2005
  • Nov 11, 2005
part number is in my sig. All you basically need to do is install the mazda (1978) pickup bearing and your good. Same shifter, same driveshaft, same mount, ..........all should be good. Even same clutch (or at least I used the same one). good luck
Jack
R
ratrapp2
121
  • Nov 12, 2005
4.30 will be way to low a gear with the 4 banger tranny.i used 3.55s and 3.73s when i was using a 4 banger tranny and the car actually went faster with 3.55s.those trannys are tougher than most people think.i never exploded mine,i just replaced it with a t-5z but i actually liked the 4 cylinder model better.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
F
C4 Transmission
  • Fri Guy
  • Jan 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
LILCBRA
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
