so ive got ranger (fox width) axles and drums, and 95 calipers/soft lines, with all the 5 lug stuff up there. this winter i plan on getting a set of 99-04 pbr calipers (non cobra) i know ill have to grind my 95 spindle to fit it, but thats fine, then the rear i want to do a disc on now. that famous 5 lug site says i need
driver side Ranger axles or passenger side Aerostar axles (2)
94+ GT/V6 10.5" solid rear rotors (2)
sn95 calipers from 94-98 v6/gt/cobra (2)
soft brake lines (2)
pads for 94+ GT/V6 (1 set)
North RaceCar brackets (2)
FMS M2809A ebrake cables for 87-92 car (2) - or 93 Cobra cables for 1993 cars (2) F3ZZ-2A635-A
FMS M2810A center ebrake cable (1)
adapter from softline to hard lines (2)
why do i need those north racecar brackets? i cant just pull it all from a junkyard? cause the track is wider on the sn's right?
i basically want 99-04 gt/v6 front and rear calipers, which would leave me guessing that i need a 99-04 booster and master cyl right? or would my master be okay but just need a booster? i was figuring i might as well do the booster and mc, that way my brakes would be just like the factory 99-04 ones but on a fox, and with 95 spindles and fox width rear stuff.
and i was probably going to do ss brake lines while i was at it. good idea? and will i have to mess with flaring tools and such and modify hardlines?
this stuff is 94-98 real caliper oriented isnt it? are they much worse than the 99-04 rear calipers?
