I woudl go allt he way to 460 if you are gonna spend money on big block. the 400m is not that great and you will need to do some pretty significant modifications to install including pan change (oil pickup as well) trans tunnel clearance for C6 (C6 heavy power robbing trans) and dirveshaft sense the C6 is longer then C4 or t5. Also need some swap headers and new exhaust and motor mount bracket kit for big block. If you like the idea of the carb 400 go with cleveland setup which uses all same stuff as small block for install and will jsut need different pan and exhaust.
