408 Build-Up
  • Thread starter Thread starter stlboarder
  • Start date Start date May 10, 2004
stlboarder
215
Arizona
May 10, 2004
  • May 10, 2004
I also put this in the Race Tech forum but I haven't gotten any responses sooo... :
This summer I plan on building a 408 from a 351W block. I will be putting it in my '95 so I will run fuel injection unless you guys think it would be better to run a carb. So far I think I am going to run a Edelbrock Performer RPM intake and I was thinking either Twisted Wedge heads or Performer RPM heads. What do you guys recommend. Would there be any other heads you think I should look into. I was looking at the DSS 408 stroker kit and I haven't heard much about it... are there any others?
Iowa91LX
2,616
Grundy Center, Iowa
May 10, 2004
  • May 10, 2004
There are tons of companies that make a 408 stroker kit. I went with DSS on mine.
I went with Total Engine Airflow to CNC my Twisted Wedge heads and they flow awesome and make tons of power. Depending on what you want the car to do and where you want your power at, look into custom cams, and a good head. Both TFS and AFR have done nothing but impress me.
Also I went with a carbed setup on mine and kindof glad I did. I have awesome throttle response and I can adjust the idle to work my large cam. If you do stay with EFI then your going to have to look into a custom chip and possibly a different computer all together.
Only downfall I have found with my carb is the cleaning of it and it does need to be adjusted from time to time. Unlike your EFI. I also spent a lot of money on my carb though. I didnt go through Summit and just order one and bolt it on. I had a shop build one for my motor specifically and it works great.
stlboarder
215
Arizona
May 10, 2004
  • May 10, 2004
What kind of power do you get with your 408 and what kind of fuel mileage to you get?
Iowa91LX
2,616
Grundy Center, Iowa
May 10, 2004
  • May 10, 2004
Never had it dyno'd but probably 500-550RWHP, and I get about 7-10MPG? Ive never figured the mileage. All I know is that its terrible.
stlboarder
215
Arizona
May 10, 2004
  • May 10, 2004
Well I guess that it is a good trade off for power and huge torque... I just won't use the gas a whole lot and it might be a little better.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
