408 compression ratio
I am building a 408. Have a 69 block with girdle. Scat 4" forged crank and Scat 6.200 forged H-beam rods. I am going N/A for now but may be adding a vortech in the near future. What is a safe compression ratio to shoot for that will run good for N/A but not be too much for a blower? Need to know before I buy my pistons. Thanks in advance.
I'd shoot for 9.0-9.3. Thats a good ratio that makes good NA power and can even function with regular unleaded when NA if you have a good tune. If its a street car I wouldnt go over 12 psi. Just make sure you use a boost cooler kit or intercooler.
Depends...do you like buying race fuel?
Than stay under 10:1 unless your runing a blow thou carb or a big intercooler or both.
p.s. if you dont got heads yet,get heads with a larger CC volume,much rather have more CC volume than a thicker head gasket.
Well your block height is 9.48" (or should be, have you had it checked) so with that 4" stroke crank, 6.2" rod your going to need a piston with a CH of 1.28".
JE makes a shelf piston with a -30cc inverted dome, they use a .927" pin so as long as your rods are .927 you should fine....only thing I could find in my catalogs.
Here is what I come up with..
Bore Size: 4.030
Gasket Bore: 4.100
Piston Top Land Dia: 3.995
Stroke: 4.000
Connecting Rod Length 6.200
Compression Height: 1.280
Deck Height: 9.480
Ring to Top of Piston 0.250
Gasket Thickness: 0.040
Valve Notches Volume: 30.00
Dome Volume: 0.00
Volume Head: 58.00
:COMPRESSION RATIO: 9.570
calculation variables:
Piston to Deck: 0.000
Crank Throw: 2.000
Vol. Above Top Ring: 0.90 cc
Piston to Dec Vol.: 0.00 cc
Gasket Volume: 8.65 cc
Volume Clearance: 97.56 cc
Cylinder Volume: 836.10 cc
CID: 408.018
Switching to a .050" headgasket will get you 9.38:1, if you want less then that then you'll need to go Custom as far as I know. I can't find a larger shelf stock dish to lower the compression. By using a .050 you still have suffucient quench area.
What blower model will you be adding, you'll need atleast a T -trim preferrably a YS-trim (if you want to stay Vortech) to feed that large cubic inch motor, a S-trim just won't cut it.
Bore Size: 4.030
Gasket Bore: 4.100
Stroke: 4.000
Deck Height: 9.480
Dome Volume: 0.00
Volume Head: 58.00
Crank Throw: 2.000
CID: 408.018
That is the largest dish I could find also. And yes it would be a vortech ys trim.
You could always build it 10.5:1 N/A and not use the blower.
9.6:1 is a little high, but still usable with boost. I deally it would be 8.5 or 9:1 for a future with the Vortech. You'll have the ability to split that block anyway. It wont be a real threat until around 700+fwhp, though.
I asked myself the same question when I built my 408, as I plan on boost in the future as well.
I went about as low as I could get away with N/A. The motor is pretty healthy now, without boost. Lower compression ratios mean you can run more boost later.
CR is in my sig.
CR is in my sig.
So did you have to go with a custom piston? or did you just have larger cc heads
Going from memory...
The pistons are from Probe and have a 20cc dish.
The heads had a fairly large 73cc chamber. I have not been able to find these heads listed anywhere, but this is what the machine shop measured them as. I bought them used, and have no way of contacting the previous owner. They do not appear to have been machined.
