42# injector question
Stimmel
I have a set of what I was told to be 42# injectors they are indeed green top injectors they are denso injectors as well the only part number on the side is 195500 1980 can anyone help me and will these work on a mustang?
Thanks
You state that they are 42's, but ask if they are 42's?
Google the part number... that usually works...
If you don't find anything then I can compare your number to the 42's I have (from ford) some time tomorrow....
im sorry for the confusing post they look just like 42# injectors they part number says they are for a mazda mpv mini van...any help is appricatied ill get pics up tommorw
I've spent more than just a couple of minutes trying to find out info about your injectors. There is litterally none available. You need to be careful as to whether they're low or high impedence. Ford uses high impedence injectors. You can just use an ohm meter to test. Lows are around 5 and below and highs are above 10. I also find it highly unlikely that they put 42 pound injectors into an MPV.
