For Sale 438w Dart Iron Eagle
TOOLOW91
8,750
234
S.I.NY
For Sale - 15k
438cu in Windsor
9.5 Deck DART iron eagle .
Eagle crank
GRP rods
Diamond pistons with coated skirts
Harland sharp shaft mount rockers with BBC trunions
Isky Red Zone bushed lifters
Brian Freezy “ Freezy 74” Custom solid roller cam
Jesel belt drive
Trick Flow 225R head cleaned up by Slawko
Victor Junior intake Ported by Slawko
6061 Intake elbow
Accufab throttle body setup for Vibrant Vanjen clamp
Custom fuel rails by Moran for Sized for Alcohol
Moroso oil pan with billet rails
Motor and mid plate included
Will include methanol tune up for Holley dominator as well .
Built by Gill Davis racing engines. Engine has 11.5:1 compression setup for methanol . Comes with a extra pistons if you desire to lower the compression to 9.5:1 and custom Freezy cam for gas setup as well. Rods are brand new and engine has two passes on it . Combo has been a best of 4.97 at 146 in ultra trim with a ysi with a soft tune up in it . Cam specs can be discussed with serious buyers . Gill can be contacted with any questions on the engine build as well if needed .
Chris Alston Gear drive , Vortech V24 xb105 , Watermen mini Bertha cable drive fuel pump, and billet atomizer 500 injectors available separate or as a package deal with engine .
Engine is located in South Jersey . Listing for a good friend of mine . Serious inquires will be put directly in touch with him . I am listing for him as he doesn’t have much time to get on here .
Reactions: RaggedGT
