I have a Factory Five Cobra Replia with a 1988 5.0 converted to carb. Radiator is a new 3-row, with a 16" electric fan. I have had an coolant loss problem for a while. Last year, I pulled the intake, and found ripped gaskets by the front coolant cross-over, and brown foam on the PCV & intake. Once this was fixed, the problem went away. After open-tracking the car a few days back, did I have problems again.
Here's where I stand:
OK, ran the cylinders last night with the intake off.
Cylinders 2,3,4,5,6,7 were all 155 to 165 (Not bad for 200K+ miles!)
#8 was 145-150
#1 was 140-145
After each test, I let the guage sit for 5 minites to see if there was any pressure drop. Only #1 very, very slowly lost 3 lbs during that time, but I could not hear any hissing or gurgling noise.
A visual inspection showed the following:
Spark plugs show no iron depisits, just the car running rich.
My Moroso "T" is still intact, and not leaking
All intake manifold gaskets intact & not broken
PCV valve clean, no brown foam
Underside of intake clean, no brown foam.
The only thing I did not get to was opening the oil drain plug to check for water, but it seems unlikely.
So, based on the above, I have two thoughts:
#1 - I just had too much advanced timing in it, not enough coolant, the coolant was mostly water, my catch tank allowed air to be pulled into the cooling system, and my location for the temp gauge was in the wrong spot(rear of manifold). Put it back together with the temp gauge up front, make sure it's full of good coolant, and go on my way.
or
#2 - I remember hearing somewhere that 5.0's to kill head gaskets in the forward cylinders (#1 & #8) where the water jacket is, and mine could only have a very small opening, but enough to cause my problems.
What's your take?
Many, many thanks from an old Classics guy!:SNSign:
#8 was 145-150
#1 was 140-145
or
What's your take?
