5.0 engine shakes real bad
  • Thread starter Thread starter dirtyboy069
  • Start date Start date Feb 20, 2010
dirtyboy069
12
Chouteau
Feb 20, 2010
  • Feb 20, 2010
I just bout my wife a 95 5.0 Gt the engine starts up just fine and its not missing that i can tell but the motor shakes real bad what could it be harmonic balancer? i have had one crack on me on my old 5.0 what should i do?
2000xp8
SN Certified Technician
Aug 8, 2003
8,072
1,656
194
NJ
Feb 20, 2010
  • Feb 20, 2010
If in doubt, change it immediately.
A bad balancer can and will ruin an engine. Don't drive it again or even start it.
A new ford balancer is only like $65-$85 bucks.
If it shakes with the car in neutral, likely it is the balancer.
dirtyboy069
12
Chouteau
Feb 20, 2010
  • Feb 20, 2010
5.0 shakes
I have a balancer laying in my shop its new i will throw it on there but if thats not it i would like to have a check list of what it could be i changed the oil in it drove it to walmart and back 5miles and its doing this now
dirtyboy069
12
Chouteau
Feb 20, 2010
  • Feb 20, 2010
what other than a balancer could it be i mean it shakes bad
2000xp8
Aug 8, 2003
8,072
1,656
194
NJ
Feb 20, 2010
  • Feb 20, 2010
Well, it's pretty simple actually.
If it does it with the car in neutral and parked, it's the flywheel forward.
If it does it while the car is in motion only, it's the trans backwards.
I've had the balancer shake, it's rather violent and destructive to the engine, even if it doesn't kill the engine immediately, a bad balanacer can start an engines demise.
The balancer should really fall under routine maintainance.
Make sure the one you have laying around is the correct balancer and try it out.
With a puller it should only take about 20 minutes.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Feb 21, 2010
  • Feb 21, 2010
Do you have a spark tool? Check to see that all the igntion wires are firing, the firing order is correct and then all the spark plugs are in good condition.
If all that checks out, pull a plug wire one at a time and see if the way the engine runs changes. It should. If it doesn't, then it's a good sign that cylinder is not firing and your injector could be clogged or other. Of course, if that was true, the spark plug on that cylinder would give it away before even needing to do that.
This is of course if it's not the balancer.
Is this a 5-sod or auto car?
dirtyboy069
12
Chouteau
Feb 21, 2010
  • Feb 21, 2010
Its a Automatic car
71 blown vert
Toronto, Ontario
Feb 21, 2010
  • Feb 21, 2010
Motor mount???
I also had a wire on my regulator that was broken but would only break contact when the motor rocked with the cam lope at idle.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
