5.0 just dies in the middle of a drive?
  • Thread starter Thread starter cobracoupe
  • Start date Start date Feb 8, 2009
C
cobracoupe
10
  • Feb 8, 2009
I have a pretty simple setup, just a rebuilt 5.0 the standard boltons with a SCT chip (tuned) and a MSD distributor with a big MAF, I think its 85mm. When i start up the car and drive around it works great, the problem im having is ill be cruising on the highway not getting on it or nothing just cruising and the engine will start to sputter a lot of black smoke will come out of the exhaust it will be powerless and it will die. It will start back up and run great again if i pull the power from the battery for like a minute and reconnect it usually.
It doesn't make any sence to me.
It does have a wire tuck job done in the driver side fender wher i found a wire grounding out a while back and it was killing the car but i fixed that wire, (the wire was a yellow one coming from the starter solenoid).
Any thought at all would be appreciated.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Feb 8, 2009
  • Feb 8, 2009
MSD distributors have a history of problems. Check this and other posts on the Corral.
F
FORDBOY1516
23
  • Feb 8, 2009
thanks this helped me out i had an issue back when i bought a car it had it on the car died and won't run right picked the car up for $$1500 car was a clean 89 fox hatch from the second i got it back to my shop i thought it was the dizzy but changed every thing else before puting a stock one on havent had a problem since!
HISSIN50
34
129
Feb 9, 2009
  • Feb 9, 2009
Pull the codes if you haven't. Because it runs better after clearing the KAM, you might have a cookie stored (the CEL need not be on to store a code, esp on intermittant problems).
Good luck.
bubba-dough
1,044
Indiana
Feb 9, 2009
  • Feb 9, 2009
My buddy had problems with his MSD distributor just like what is being described.
But I would do what Hissin mentioned first. Its cheap and easy.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2009
  • Feb 9, 2009
More verses of the same song...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
C
cobracoupe
10
  • Feb 10, 2009
Okay i put my old dist in and it drove okay, but then it died again going through a drive through, the difference is it started back up with out me getting out and waiting for a while.
I'm convinced that the dist is the problem so I'm going to return my MSD one and get a new dist.
what is the BEST dist to get out there for a OEM replacement?
how does the accel compare to a new motocraft?
bubba-dough
1,044
Indiana
Feb 10, 2009
  • Feb 10, 2009
IMHO the Ford one is the best choice believe it not.
HISSIN50
34
129
Feb 10, 2009
  • Feb 10, 2009
I'd agree. If you dont turn high RPM, the stocker about as good as anything.
C
cobracoupe
10
#10
  • Feb 10, 2009
  • #10
okay well i guess motocraft it is, ill go order it today and see if it does the trick. Thankyou
afast93stang
1,407
North Texas
Feb 10, 2009
#11
  • Feb 10, 2009
  • #11
I would say its something with the MSD distributor.
I had a MSD distributor fail on me 3 months ago after 2 years of use. My car doesnt see any track time or have any heavy mods, its my daily driver...
I went back to a Ford unit.
F
fastfiftymike
47
#12
  • Feb 10, 2009
  • #12
You check your TFI module?
I had a problem like this with the stocker, and it was a bad TFI module...car just shuts off no spark, the module was overheating/broken.
Mike
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
3K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
