Expired 5.0 Mustang Engine and Transmission on a rolling chassis
mstngcbra42
Glendale, CA
$2500 obo
Engine Specs (part # M6007XB3)
- Roughly 35,000 miles
- Bore: 4.0
- Stroke: 3.0
- Displacement: 302 CID
- Nominal Compression Ratio: 9.0:1
- Block Height: 8.206
- Piston to Deck: .0075 below to .0135 above
- Camshaft: (Hydraulic Roller)
- Maximum Valve Lift .480
- Duration at .050 lift 224
- Intake Centerline 107
- Lifters: Current production
- Valves: M-6007-B50/B51/XB3/XE3
- Valve Springs: M-6513-A50
- Rocker Arms: Current Production 5.0L GT
- Combustion Chamber Volume: M-6007-B50/B51/XB3/XE3
Tremec transmission
- driven less than 50 miles since rebuild
- new clutch
Additional Parts
- Cobra Upper and Lower Intake Manifold
- Edlebrock High-flow Water Pump
- 3 Row Aluminum Radiator
- Bilstein shocks
- Bassani x pipe
- Flow-master Exhaust
- Rollerrockers
- aluminum driveshaft
- 3.73 gears
- Cobra R wheels
The section between the hood and the windsheild is dented. The front spoiler is messed up and the rear torque box needs to be repaired because its cracked. If you are interested in this vehicle what you are buying is everything to put into a shell: engine, tranny, and additional parts from the car.
Sorry for not being clear. You are getting the entire car, but what your really paying for is the engine, tranny, and additional parts from the car.
