5.0 Overheating
  • Thread starter Thread starter forzalife
  • Start date Start date Jun 4, 2014
1 of 2 Next Last
F
forzalife
186
West Palm Beach, Florida
Jun 4, 2014
  • Jun 4, 2014
Hey my motor is overheating. I put a hose to the radiator and reservoir and neither seem to hold water, especially the reservoir. I found a puddle of brown coolant as soon as i parked. Also i hear a puff and a whistle from the left side around the header? I hear the water boiling inside the engine. Its night so i cant see. Help me pros
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 4, 2014
  • Jun 4, 2014
Young Skywalker is back. Hey Luke, how's the 3 lug nuts per wheels and the monkey suspension working?
You hear boiling in the engine? That's not good
F
forzalife
186
Jun 4, 2014
  • Jun 4, 2014
Not working very good right now.hey at least it goes
F
forzalife
186
Jun 4, 2014
  • Jun 4, 2014
I need to swap to an ls1 soon cuz i know my engine is hurting. For now i need to fix this
Spaz
80
11
Pennsylvania
Jun 5, 2014
  • Jun 5, 2014
Well once it is daylight, try to see where the water is coming out. You say the coolant tank won't hold water? It's right there so where is the water coming out of? Same thing for the radiator. You are adding water to the radiator neck and you would see if it was leaking out somewhere. The more serious issue is whatever is going on near the header. Is is just an exhaust leak or do you have a blown head gasket? If it was a blown head gasket that would explain why you keep losing water. Check your oil. If it is turning milky, that means coolant/water is mixing in the oil and you probably have a blown head gasket. White smoke coming out of the exhaust also means coolant/water is getting into the combustion chambers = likely blown head gasket.
F
forzalife
186
Jun 5, 2014
  • Jun 5, 2014
I checked and saw no holes in radiator or resevoir. I do have a check oil light.
stykthyn
5,232
2,652
223
gainesville
Jun 5, 2014
  • Jun 5, 2014
Easy young Skywalker. Change the oil. If it looks like chocolate milk go ahead and just install that ls motor. If the oil is good take your car to a shop to have the cooling system pressure tested. Costs around 60 dollars abd will tell you exactly where the problem is. If that's too much money Buy a bike and start peddling.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 5, 2014
  • Jun 5, 2014
$60? This is the same kid who can't afford to put a 4th lug nut on his wheel. Some people are bus riders.
stykthyn
5,232
2,652
223
gainesville
Jun 6, 2014
  • Jun 6, 2014
I know I know but if he can't diagnose a leak big enough that a hose can't keep it full then he's best off paying the semi pros to do it until he can graduate and figure it out himself. I started there at one point and I am sure many others did as well.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 6, 2014
#10
  • Jun 6, 2014
  • #10
Agree 100%. It's no shame to admit you are over your head. I made plenty of mistakes when I was young and thought I knew everything. Put together my first motor at 15 with no torque wrench, re used evey bolt I could find. The damn motor ran for 2 years until I blew it up at Englishtown. Go figure.
stykthyn
5,232
2,652
223
gainesville
Jun 6, 2014
#11
  • Jun 6, 2014
  • #11
I still fubar, I just don't talk about it in the webz ;D
Reactions: RangerJoe
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 6, 2014
#12
  • Jun 6, 2014
  • #12
How is this kid ever going to tackle an LS swap? He'd be better of swapping in a junkyard Explorer engine and call it a day.
....but I know he won't listen.
stykthyn
5,232
2,652
223
gainesville
Jun 6, 2014
#13
  • Jun 6, 2014
  • #13
Onefine88
Previously 89SSC18
1,422
796
154
Jun 6, 2014
#14
  • Jun 6, 2014
  • #14
LOL
stykthyn
5,232
2,652
223
gainesville
Jun 6, 2014
#15
  • Jun 6, 2014
  • #15
I haven't enjoyed a poster this much since ryan218
smkshw
5 Year Member
Feb 12, 2010
1,095
235
94
Jun 6, 2014
#16
  • Jun 6, 2014
  • #16
i was thinking the same thing,never mind a head gasket cause it sounds like it is....but theres always block and headgasket seal...!
F
forzalife
186
Jun 6, 2014
#17
  • Jun 6, 2014
  • #17
Its called "pay the grease monkey to do it for me". oh by the way i bought all the lugs (installed myself) also my wife got a job i got a huge raise and my rent went way down. Im not too worried right now
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 6, 2014
#18
  • Jun 6, 2014
  • #18
WOW!!!! You installed the lug nuts by yourself???
That LS swap should be a no brainer
stykthyn
5,232
2,652
223
gainesville
Jun 6, 2014
#19
  • Jun 6, 2014
  • #19
Seriously then get to work diagnosing your car or have someone do it for you. Your engine will be a pile of scrap if you keep running it with a bad overheat issue like that.
F
forzalife
186
Jun 6, 2014
#20
  • Jun 6, 2014
  • #20
Lol mikestang what a hater i was obviously being sarcastic about deez nuts. Your not contributing to this post anymore, just being negative why dont you see your way out?
1 of 2 Next Last
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
Progress Thread severe97's Project Thread!
  • severe97
  • Jan 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 1, 2025
severe97
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
