Well, I've taken off the water pump, timing chain cover, timing gear set, headers, oil pan, engine mounts, and oil pump.... Looking to take the cam out.. Do I need to pull the valves, lifters and rods off before the cam or can I go ahead and pull the cam out next then move back to the top? It doesn't say either way in the chiltons... lol.. YES, I said it, I'm rebuilding an engine using a chiltons with absolutely NO experience.... Wish Me Luck![]()
'89, you can come-by and get a quick reference lesson. I have engines on stands now to show you what you're up against. At the end of the day, it's very simple, you just need to build one -once or twice. Get an all thread or long bolt from the parts store to pull the cam out. Like Blur wrote above, the lifters must come out. Take off the spider hold down, remove the dog bones that keep the lifters aligned and pull the 16 lifters out and put them in oil. Be careful when you pull the cam out. Don't knock the cam into the cam bearings.
