5.0 rebuild
  • Thread starter Thread starter dbdragracing
  • Start date Start date Jan 5, 2009
dbdragracing
397
Jan 5, 2009
  • Jan 5, 2009
I have a 1991 GT and I'm removing the 133K 5.0 to fix a little rust in the driver side shock tower...what is the typical cost to have the engine freshened up? I figure I might as well while its out. Thanks.
dbdragracing
397
Jan 6, 2009
  • Jan 6, 2009
Anyone had their's rebuilt? Thanks.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 6, 2009
  • Jan 6, 2009
It probably shouldn't be too much, but you never know what you're looking at cost-wise, until you break her open. If your rod and main journals look good, you might get away with new bearings and a re-ring. It could end up with undercut mains on the crank, a .030 overbore, etc. On the low end, I'd say you might be able to do it as cheaply as a few hundred bucks if everything is in good shape. On the high end, you could be upwards of a grand, figuring the worst case scenario.
90topdown
138
Philadelphia, PA
Jan 6, 2009
  • Jan 6, 2009
It really depends on what you have done to it. I would budget $2500.
Are you having any troubles with the engine??
I would check the oil pressure with a mechanical guage as well as do a leak down test before doing anything with the motor because................. if it ain't broke.......................don't fix it.
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 20, 2025
