5.0 sensor stuff...
  • Thread starter Thread starter iv2jm
  • Start date Start date Feb 4, 2004
I
iv2jm
23
  • Feb 4, 2004
I basically bought a 91 motor from a friend, including the wiring harness, complete intake, computer, ignition and injection. My plan is for it to go in my 66 mustang, which is obviously not wired for fuel injection. i know quite a bit about the 5.0, and im pretty certain its a stand alone system, so i can just power the computer, switch it on, and use mass air, O2, and tps sensors. can i ignore the BAP and inertial switch?
also, what size are stock 5.0 fuel lines? i think supply is 5/16 and return 1/4...is his correct?
Thanks for the help guys
Jimmy
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 4, 2004
  • Feb 4, 2004
The BAP or MAP sensor is to measure the atmospheric pressure and is used to help set the air/fuel ratio. The computer will set code 22 and run in limp mode.
The inertia switch protects you from fire if the car is in an accident. It shuts off the fuel pump to reduce the fire hazard. Unless you are flameproof, you should install it.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Pm Ranchero5.0, he has done a similar swap, and should have some ideas to help.
I
iv2jm
23
  • Feb 8, 2004
thanks for the diagrams, ive been looking for some good ones...can i just take out the egr, without putting the car into super rich mode? or if i do that will it trigger the computer to suck?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 8, 2004
  • Feb 8, 2004
You can remove the EGR, but the gas mileage will suffer. The EGR closes at idle and full throttle, so it doesn't cost any HP. There are EGR elminators and block off plates if you need them. If you are going to do EFI, might as well have all the stuff that makes the car run right without setting any codes.
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • dan50
  • Jul 18, 2026
dan50
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
